[postgis-users] How to make some geometry column visible to Qgis
Francois Hugues hugues.francois at irstea.fr
Mon Oct 22 01:38:08 PDT 2012
Hello
"This because I cannot remove the entities geometry column unless I remove the entity table first.
And if I don't remove (or make invisible to qgis if possible) the entities geometry column it slow down the qgis connection."
Did you try to edit the view, using the where clause to exclude the tables you don't want to be seen by postgis ?
Hugues.
De : postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] De la part de Pietro Rossin
Envoyé : lundi 22 octobre 2012 09:25
À : postgis-users at postgis.refractions.net
Objet : Re: [postgis-users] How to make some geometry column visible to Qgis
DELETE FROM geometry_columns WHERE f_table_name = 'puntigronda';
Query returned successfully: 0 rows affected, 0 ms execution time.
INSERT INTO geometry_columns (f_table_catalog,f_table_schema, f_table_name, f_geometry_column, coord_dimension, srid,type)Â
  VALUES ('','', 'puntigronda', 'the_geom', 3, 3004,'POINTS');
Query returned successfully: 0 rows affected, 16 ms execution time.
select relkind from pg_class where relname = 'geometry_columns';
returns:
"v"
What is this?
By the way
If my technique works, is it still better to explode the "entities" table in one of this cases:
a) single layers
b) same kind of geometries
in both cases table permanent.
Thanks for your help
Pietro
2012/10/22 Sandro Santilli [via PostGIS] <[hidden email]>
	> Is there something wrong?
	What's wrong is that the "geometry_columns" table should be a view,
	in PostGIS-2.0. If it is a view, your DELETE and INSERT and UPDATE
	to it should have no effect.
	Can you verify this first ?
	The DELETE/INSERT/UPDATE commands all return the number of affected
	rows. If PostGIS is correctly installed you should alwyas get 0,
	no matter what you try to insert/delete/update.
	Also check:
	--strk;
	 http://www.cartodb.com - Map, analyze and build applications with your data
	                                       ~~ http://strk.keybit.net
	postgis-users mailing list
	[hidden email] <http://user/SendEmail.jtp?type=node&node=5000684&i=0>
	http://postgis.refractions.net/mailman/listinfo/postgis-users
	If you reply to this email, your message will be added to the discussion below:
	http://postgis.17.n6.nabble.com/How-to-make-some-geometry-column-visible-to-Qgis-tp5000570p5000684.html
	To unsubscribe from How to make some geometry column visible to Qgis, click here.
	NAML <http://postgis.17.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: Re: How to make some geometry column visible to Qgis <http://postgis.17.n6.nabble.com/How-to-make-some-geometry-column-visible-to-Qgis-tp5000570p5000685.html>
Sent from the PostGIS - User mailing list archive <http://postgis.17.n6.nabble.com/PostGIS-User-f3516033.html>  at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121022/08711967/attachment.html>
