[postgis-users] LinestringZ not valid
Chris English
sglish at hotmail.com
Mon Oct 22 11:27:29 PDT 2012
select st_isvalid(a.p), st_isvalid(b.q) from
(select st_geomfromtext('LINESTRINGZ(0 0 0, 1 0 0)')as p) as a,
(select st_geomfromtext('LINESTRINGZ(0 0 0, 0.00000001 0 10000)') as q) as b;
st_isvalid (a.p) st_isvalid(b.q)
t t
LINESTRING(s) have an work obligation to go somewhere, even if a very small distance,
and .5D doesn't constitute enough of a dimension to have gone somewhere as strk points out.
Chris
> Date: Mon, 22 Oct 2012 09:40:46 -0700
> From: ps.tiara at yahoo.com
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] LinestringZ not valid
> Hello,
> I've tried to make a linestring with z value as below
> from (select st_geomfromtext ('LINESTRING Z(0 0 0, 1 0 0)') as p) as a,
> (select st_geomfromtext('LINESTRING Z(0 0 0, 0 0 1)') as q) as b
> the result shows that linestring from table b is not valid,,it's caused too
> few points..
> is it impossible to make linestring (0 0 0, 0 0 1) ? how to make it valid?
> thanks..
> --t
> View this message in context: http://postgis.17.n6.nabble.com/LinestringZ-not-valid-tp5000695.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
