[postgis-users] Pg_wrapper error
Bborie Park bkpark at ucdavis.edu
Thu Oct 25 09:51:39 PDT 2012
You're probably going to want to call raster2pgsql directly instead of
pg_wrapper.  If the problem is with pg_wrapper, you're better asking a
debian mailing list.
So...
/usr/bin/raster2pgsql MYRASTER MYTABLE | psql -d MYDB
-bborie
On 10/25/2012 08:26 AM, José Pedro Santos wrote:
> Dear all,
> I have one problem when I try to load raster to Postgis with the script raster2pgsql from the shell.
> I have this error: Error: pg_wrapper: invalid command name
> Before this error (I have Postgis version 2.0) I can't use the command (raster2pgsql) in the shell (was not found) but i enable it with this expression:
> sudo ln -sf /usr/share/postgresql-common/pg_wrapper /usr/bin/raster2pgsql
> After that the error about pg_wrapper appear.
> Any suggestion?
> Best Regards and thanks,
> Jose Santos
> postgis-users mailing list
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
