[postgis-users] Pg_wrapper error
José Pedro Santos
zpsantos1 at hotmail.com
Fri Oct 26 02:28:20 PDT 2012
Thanks for the reply but I already call raster2pgsql. In the beginning says that I don't have the command raster2pgsql available and them I just enable it, after that appear the pg_wrapper error.
Now the error pass to pg_wrapper...
The problem its not the raster2pgsql.
Regards,
Jose Santos
> Date: Thu, 25 Oct 2012 09:51:39 -0700
> From: bkpark at ucdavis.edu
> To: postgis-users at postgis.refractions.net
> Subject: Re: [postgis-users] Pg_wrapper error
> You're probably going to want to call raster2pgsql directly instead of
> pg_wrapper. If the problem is with pg_wrapper, you're better asking a
> debian mailing list.
> So...
> /usr/bin/raster2pgsql MYRASTER MYTABLE | psql -d MYDB
> -bborie
> On 10/25/2012 08:26 AM, José Pedro Santos wrote:
> > Dear all,
> > I have one problem when I try to load raster to Postgis with the script raster2pgsql from the shell.
> > I have this error: Error: pg_wrapper: invalid command name
> > Before this error (I have Postgis version 2.0) I can't use the command (raster2pgsql) in the shell (was not found) but i enable it with this expression:
> > sudo ln -sf /usr/share/postgresql-common/pg_wrapper /usr/bin/raster2pgsql
> > After that the error about pg_wrapper appear.
> > Any suggestion?
> > Best Regards and thanks,
> > Jose Santos
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Bborie Park
> Programmer
> Center for Vectorborne Diseases
> UC Davis
> 530-752-8380
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121026/ff158413/attachment.html>
