[postgis-users] How to eliminate small gaps produced by ST_union?
Alexandre Neto
senhor.neto at gmail.com
Thu Oct 25 09:54:05 PDT 2012
I'm trying to Aggregate\Dissolve a set of adjacent, but not touching
polygons in Postgis. The geometries were created editing the Postgis table
in QGIS created, with snapping and avoid overlap in the layer.
I used ST_Union like this:
SELECT ST_Union(the_geom)
FROM table;
Small gaps similar to lines appear in the result. This happens when the
adjacent polygons do not share the exact same vertices.
[image: Inline image 2]
Is there a way to eliminate this "gaps" or "small angles" within Postgis?
I know that v.clean in GRASS can eliminate small angles, and correct
topology, but that would mean I needed to copy the features to GRASS,
correct them and copy it back to Postgis.
Thanks in advance,
Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121025/8b14d646/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121025/8b14d646/attachment.jpeg>
