[postgis-users] Difficult Problem with Polygons
Nicolas Ribot
nicolas.ribot at gmail.com
Mon Oct 29 08:00:04 PDT 2012
If the points are computed in the right order, you can store them and
pass them to st_makeLine and st_makePolygon.
If not, you can form a segment between 2 closest points and connect it
to the closest points.
On 29 October 2012 15:37, Ed Linde <edolinde at gmail.com> wrote:
> Hi All,
> Thanks for the tips! Just another thing, when I compute the "transition
> points" on each edge (shown as red points in my pdf).
> I need to join them to make a polygon. Wondering how I can connect them
> together so that I start with a point and end on it
> to form a closed polygon?
> Cheers,
> Ed
> On Mon, Oct 29, 2012 at 3:03 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com> wrote:
>> Hi Ed,
>> Well if clarifies one thing at least, you can ignore Mike's st_Relate
>> because 5 is not adjacent to a linear edge, it is only adjacent to a vertex,
>> so st_touches should work fine.
>> so you are looking for:
>> 1. a specific triangle by id
>> 2. that intersects triangle VC
>> 3. and the triangles adjacent to triangle by id
>> 4. and those that are contained in VC
>> 5. sorted by distance to P1 limit 1
>> so something like:
>> select id, the_geom
>> from (select id, the_geom as adjacent
>> from triangles
>> where st_touches(the_geom,
>> (select the_geom
>> from triangles a,
>> (select the_geom as vc
>> from vc_table
>> where id='p1') b
>> where a.id=4)) c
>> order by st_distance(c.the_geom, (select the_geom
>> from points
>> where id='p1')) asc limit 1;
>> Untested, but should give you a model to work with.
>> -Steve W
>> On 10/29/2012 6:57 AM, Ed Linde wrote:
>>> Attached is a figure. Where the dotted line is the boundary of the
>>> voronoi cell whose
>>> generator is point P1. So triangle "4" intersects with the voronoi
>>> boundary, but we are
>>> interested in the adjacent triangles of triangle 4, which are closer to
>>> point P1.
>>> For example, triangle 5.
>>> Hope this helps.
>>> Cheers,
>>> Ed
>>> On Mon, Oct 29, 2012 at 11:50 AM, Nicolas Ribot <nicolas.ribot at gmail.com
>>> <mailto:nicolas.ribot at gmail.com>> wrote:
>>> Could you draw a figure ?
>>> Nicolas
>>> On 29 October 2012 11:03, Ed Linde <edolinde at gmail.com
>>> <mailto:edolinde at gmail.com>> wrote:
>>> > Hi All,
>>> > Thanks for the suggestions.
>>> > For 1) I will look into how ST_touches works and see if it can
>>> pick up all
>>> > the adjacent polygons to
>>> > the one I have. And also look into Mike's suggestion on
>>> ST_relate...though I
>>> > must admit it looks
>>> > more complex.
>>> > For 2) I will try to clarify it a bit more... its harder to do
>>> without a
>>> > figure :) but here goes.
>>> > Lets say we have a point Q which is the generator of a voronoi
>>> cell. Now I
>>> > compute the
>>> > intersection between the voronoi cell boundaries and my
>>> triangulation (Set
>>> > of polygons)
>>> > using ST_intersect. Once I have these triangles.. I say pick one
>>> triangle T
>>> > that is
>>> > intersecting the voronoi cell boundary of Q.
>>> > For all the triangles adjacent to T, I need to know which
>>> triangles are
>>> > INSIDE the voronoi
>>> > boundary (closer to Q) and which adjacent triangles are just
>>> OUTSIDE the
>>> > voronoi
>>> > boundary (farther from Q). I am basically testing for a certain
>>> property by
>>> > "shrinking" the
>>> > voronoi cell (closer to Q) and another property when "expanding"
>>> the voronoi
>>> > cell (away from Q).
>>> > Just need to make this division of triangles. Haven't thought of
>>> a nice way
>>> > to do this in postgis 2.0
>>> > So any suggestions would greatly help.
>>> > Thanks,
>>> > Ed
>>> > On Mon, Oct 29, 2012 at 10:15 AM, Mike Toews <mwtoews at gmail.com
>>> <mailto:mwtoews at gmail.com>> wrote:
>>> >> On 29 October 2012 21:33, Ed Linde <edolinde at gmail.com
>>> >> > Hi All,
>>> >> > I need help with 2 hard problems. I store triangles in a table
>>> as
>>> >> > POLYGON.
>>> >> > 1. I want to know for a given triangle, which triangles share
>>> an edge
>>> >> > (adjacent) with this triangle.
>>> >> Sounds like you have a finite element mesh with nodes and
>>> elements.
>>> >> You can use ST_Relate with pattern 'FF2F11212' to pick out
>>> elements
>>> >> that share the same edge. This DE-9-IM is sort-of a custom
>>> ST_Touches,
>>> >> but only takes linear boundary overlaps. So if you have a table
>>> >> "elements", and you want to find ones that touch ID 567:
>>> >> SELECT elements.*
>>> >> FROM elements, elements as e
>>> >> WHERE e.id <http://e.id> = 567 AND
>>> >> ST_Relate(elements.geom, e.geom, 'FF2F11212');
>>> >> I'm not certain about your second question.
>>> >> -Mike
>>> >> _______________________________________________
>>> >> postgis-users mailing list
>>> >> postgis-users at postgis.refractions.net
>>> <mailto:postgis-users at postgis.refractions.net>
>>> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
