[postgis-users] Difficult Problem with Polygons
Ed Linde
edolinde at gmail.com
Mon Oct 29 08:03:14 PDT 2012
Thanks Nicolas. Just about the error, is this because the line segments are
too close
and postgis 2.0 could not handle this? If so is there a workaround, even if
it means
slightly having to "perturb" each point's position to not run into this bug.
I was really hoping that the intersection of two polygonal shapes in 3D
would be fairly
simple in postgis 2.0 :(
Ed
On Mon, Oct 29, 2012 at 4:00 PM, Nicolas Ribot <nicolas.ribot at gmail.com>wrote:
> If the points are computed in the right order, you can store them and
> pass them to st_makeLine and st_makePolygon.
> If not, you can form a segment between 2 closest points and connect it
> to the closest points.
> On 29 October 2012 15:37, Ed Linde <edolinde at gmail.com> wrote:
> > Hi All,
> > Thanks for the tips! Just another thing, when I compute the "transition
> > points" on each edge (shown as red points in my pdf).
> > I need to join them to make a polygon. Wondering how I can connect them
> > together so that I start with a point and end on it
> > to form a closed polygon?
> > Cheers,
> > Ed
> > On Mon, Oct 29, 2012 at 3:03 PM, Stephen Woodbridge
> > <woodbri at swoodbridge.com> wrote:
> >> Hi Ed,
> >> Well if clarifies one thing at least, you can ignore Mike's st_Relate
> >> because 5 is not adjacent to a linear edge, it is only adjacent to a
> vertex,
> >> so st_touches should work fine.
> >> so you are looking for:
> >> 1. a specific triangle by id
> >> 2. that intersects triangle VC
> >> 3. and the triangles adjacent to triangle by id
> >> 4. and those that are contained in VC
> >> 5. sorted by distance to P1 limit 1
> >> so something like:
> >> select id, the_geom
> >> from (select id, the_geom as adjacent
> >> from triangles
> >> where st_touches(the_geom,
> >> (select the_geom
> >> from triangles a,
> >> (select the_geom as vc
> >> from vc_table
> >> where id='p1') b
> >> where a.id=4)) c
> >> order by st_distance(c.the_geom, (select the_geom
> >> from points
> >> where id='p1')) asc limit 1;
> >> Untested, but should give you a model to work with.
> >> -Steve W
> >> On 10/29/2012 6:57 AM, Ed Linde wrote:
> >>> Attached is a figure. Where the dotted line is the boundary of the
> >>> voronoi cell whose
> >>> generator is point P1. So triangle "4" intersects with the voronoi
> >>> boundary, but we are
> >>> interested in the adjacent triangles of triangle 4, which are closer to
> >>> point P1.
> >>> For example, triangle 5.
> >>> Hope this helps.
> >>> Cheers,
> >>> Ed
> >>> On Mon, Oct 29, 2012 at 11:50 AM, Nicolas Ribot <
> >>> <mailto:nicolas.ribot at gmail.com>> wrote:
> >>> Could you draw a figure ?
> >>> Nicolas
> >>> On 29 October 2012 11:03, Ed Linde <edolinde at gmail.com
> >>> <mailto:edolinde at gmail.com>> wrote:
> >>> > Hi All,
> >>> > Thanks for the suggestions.
> >>> > For 1) I will look into how ST_touches works and see if it can
> >>> pick up all
> >>> > the adjacent polygons to
> >>> > the one I have. And also look into Mike's suggestion on
> >>> ST_relate...though I
> >>> > must admit it looks
> >>> > more complex.
> >>> > For 2) I will try to clarify it a bit more... its harder to do
> >>> without a
> >>> > figure :) but here goes.
> >>> > Lets say we have a point Q which is the generator of a voronoi
> >>> cell. Now I
> >>> > compute the
> >>> > intersection between the voronoi cell boundaries and my
> >>> triangulation (Set
> >>> > of polygons)
> >>> > using ST_intersect. Once I have these triangles.. I say pick one
> >>> triangle T
> >>> > that is
> >>> > intersecting the voronoi cell boundary of Q.
> >>> > For all the triangles adjacent to T, I need to know which
> >>> triangles are
> >>> > INSIDE the voronoi
> >>> > boundary (closer to Q) and which adjacent triangles are just
> >>> OUTSIDE the
> >>> > voronoi
> >>> > boundary (farther from Q). I am basically testing for a certain
> >>> property by
> >>> > "shrinking" the
> >>> > voronoi cell (closer to Q) and another property when "expanding"
> >>> the voronoi
> >>> > cell (away from Q).
> >>> > Just need to make this division of triangles. Haven't thought of
> >>> a nice way
> >>> > to do this in postgis 2.0
> >>> > So any suggestions would greatly help.
> >>> > Thanks,
> >>> > Ed
> >>> > On Mon, Oct 29, 2012 at 10:15 AM, Mike Toews <mwtoews at gmail.com
> >>> <mailto:mwtoews at gmail.com>> wrote:
> >>> >> On 29 October 2012 21:33, Ed Linde <edolinde at gmail.com
> >>> >> > Hi All,
> >>> >> > I need help with 2 hard problems. I store triangles in a
> table
> >>> as
> >>> >> > POLYGON.
> >>> >> > 1. I want to know for a given triangle, which triangles share
> >>> an edge
> >>> >> > (adjacent) with this triangle.
> >>> >> Sounds like you have a finite element mesh with nodes and
> >>> elements.
> >>> >> You can use ST_Relate with pattern 'FF2F11212' to pick out
> >>> elements
> >>> >> that share the same edge. This DE-9-IM is sort-of a custom
> >>> ST_Touches,
> >>> >> but only takes linear boundary overlaps. So if you have a table
> >>> >> "elements", and you want to find ones that touch ID 567:
> >>> >> SELECT elements.*
> >>> >> FROM elements, elements as e
> >>> >> WHERE e.id <http://e.id> = 567 AND
> >>> >> ST_Relate(elements.geom, e.geom, 'FF2F11212');
> >>> >> I'm not certain about your second question.
> >>> >> -Mike
> >>> >> _______________________________________________
> >>> >> postgis-users mailing list
> >>> >> postgis-users at postgis.refractions.net
> >>> <mailto:postgis-users at postgis.refractions.net>
> >>> >> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121029/b545e7ca/attachment.html>
