[postgis-users] Problem with 3D polygon intersection test
Nicolas Ribot
nicolas.ribot at gmail.com
Tue Oct 30 03:04:13 PDT 2012
st_dumpRings will return the rings (closed linestrings) composing the
polygon (exterior first, then interiors)
and st_dumpPoints will return all the points forming the rings, in the
right order.
Nicolas
On 30 October 2012 10:56, Ed Linde <edolinde at gmail.com> wrote:
> Ok, for a polygon, is there a good postgis function that can return the
> edges to me in the
> right sequence? Or at least the points that constitute the polygon in the
> right order, so I can
> generate the edges in a script?
> Thanks,
> Ed
> On Tue, Oct 30, 2012 at 10:46 AM, Ed Linde <edolinde at gmail.com> wrote:
>> Ah drat! Ok then I have to basically do edge intersection tests by
>> myself.
>> Ah well. bad news! :(
>> On Tue, Oct 30, 2012 at 10:44 AM, Nicolas Ribot <nicolas.ribot at gmail.com>wrote:
>>> Hi,
>>> st_intersection is only suitable for 2D operations. Third dimension is
>>> not taken into account.
>>> Nicolas
>>> On 30 October 2012 09:44, Ed Linde <edolinde at gmail.com> wrote:
>>>> Hi All,
>>>> Is there a simpler test I can do? I am quite sure that I am probably
>>>> not using the right
>>>> function in my SQL, or not doing the intersection test correctly. Is
>>>> there any simpler
>>>> way to test this 3D intersection? Am waiting on the postgis gurus to
>>>> come along and
>>>> give me some ideas, coz I am at my wits ends on this one! :) The
>>>> polygons look good
>>>> to me when I visualize them, but don't get how all triangles are found
>>>> as intersecting?
>>>> Anyway will wait.
>>>> Cheers,
>>>> Ed
>>>> On Tue, Oct 30, 2012 at 9:00 AM, Ed Linde <edolinde at gmail.com> wrote:
>>>>> Hi All,
>>>>> I am having some troubles getting the *ST_Intersect* function to work
>>>>> with 3D polygons.
>>>>> I have a table to hold triangles as polygons in *"small_tris"*
>>>>> Another table for holding the polygonal faces of a 3D voronoi diagram
>>>>> in *"vfaces"*
>>>>> So now I am trying to do an intersection between the triangles and the
>>>>> voronoi faces
>>>>> to get the triangles that intersect with the faces. And it seems that
>>>>> *ALL* triangles
>>>>> are intersecting. I have attached a PDF where I have plotted the
>>>>> triangles and the
>>>>> voronoi cells. so the box around in red and blue with a major face
>>>>> going through is
>>>>> the voronoi diagram. The Voronoi partition in 3D is shown at the
>>>>> bottom too for clarity
>>>>> Can someone please help and let me know what am I doing wrong here?
>>>>> Is the select assuming something? So the polygons are flat and the
>>>>> intersections
>>>>> should just be lines or points. I am under some pressure to get this
>>>>> to work, so if
>>>>> anyone needs more information to help, the please let me know! :)
>>>>> Cheers,
>>>>> Ed
>>>>> *-- TABLE SCHEMAS*
>>>>> bounds=# \d vfaces;
>>>>> Table "public.vfaces"
>>>>> Column | Type | Modifiers
>>>>> gen_id | integer |
>>>>> geomtext | geometry |
>>>>> bounds=# \d small_tris;
>>>>> Table "public.small_tris"
>>>>> id | integer | not null
>>>>> v0 | integer |
>>>>> v1 | integer |
>>>>> v2 | integer |
>>>>> Indexes:
>>>>> "small_tris_pkey" PRIMARY KEY, btree (id)
>>>>> "small_idx" gist (geomtext)
>>>>> -- TABLE CONTENT*
>>>>> bounds=# select id, st_astext( geomtext ) from small_tris;
>>>>> id | st_astext
>>>>> 0 | POLYGON Z ((10 10 805,20 10 809,10 20 814,10 10 805))
>>>>> 1 | POLYGON Z ((10 20 814,20 10 809,20 20 819,10 20 814))
>>>>> 2 | POLYGON Z ((20 20 819,30 10 809,30 20 812,20 20 819))
>>>>> 3 | POLYGON Z ((30 10 809,20 20 819,20 10 809,30 10 809))
>>>>> 4 | POLYGON Z ((30 20 812,30 10 809,40 10 826,30 20 812))
>>>>> 5 | POLYGON Z ((20 20 819,30 20 812,20 30 827,20 20 819))
>>>>> 6 | POLYGON Z ((10 20 814,20 20 819,20 30 827,10 20 814))
>>>>> 7 | POLYGON Z ((10 40 805,10 30 814,20 30 827,10 40 805))
>>>>> 8 | POLYGON Z ((10 50 804,10 40 805,20 40 807,10 50 804))
>>>>> 9 | POLYGON Z ((20 30 827,20 40 807,10 40 805,20 30 827))
>>>>> 10 | POLYGON Z ((30 30 817,20 40 807,20 30 827,30 30 817))
>>>>> 11 | POLYGON Z ((30 40 816,20 50 809,20 40 807,30 40 816))
>>>>> 12 | POLYGON Z ((20 40 807,20 50 809,10 50 804,20 40 807))
>>>>> 13 | POLYGON Z ((10 30 814,10 20 814,20 30 827,10 30 814))
>>>>> 14 | POLYGON Z ((30 30 817,20 30 827,30 20 812,30 30 817))
>>>>> 15 | POLYGON Z ((30 20 812,40 20 823,30 30 817,30 20 812))
>>>>> 16 | POLYGON Z ((40 20 823,30 20 812,40 10 826,40 20 823))
>>>>> 17 | POLYGON Z ((40 20 823,40 10 826,50 10 803,40 20 823))
>>>>> 18 | POLYGON Z ((30 30 817,40 20 823,40 30 814,30 30 817))
>>>>> 19 | POLYGON Z ((40 20 823,50 20 808,40 30 814,40 20 823))
>>>>> 20 | POLYGON Z ((50 20 808,40 20 823,50 10 803,50 20 808))
>>>>> 21 | POLYGON Z ((40 30 814,50 20 808,50 30 816,40 30 814))
>>>>> 22 | POLYGON Z ((30 30 817,40 30 814,40 40 800,30 30 817))
>>>>> 23 | POLYGON Z ((30 40 816,40 40 800,30 50 813,30 40 816))
>>>>> 24 | POLYGON Z ((30 40 816,30 30 817,40 40 800,30 40 816))
>>>>> 25 | POLYGON Z ((30 50 813,40 40 800,40 50 817,30 50 813))
>>>>> 26 | POLYGON Z ((30 40 816,30 50 813,20 50 809,30 40 816))
>>>>> 27 | POLYGON Z ((50 40 821,40 50 817,40 40 800,50 40 821))
>>>>> 28 | POLYGON Z ((50 50 809,40 50 817,50 40 821,50 50 809))
>>>>> 29 | POLYGON Z ((50 40 821,40 40 800,50 30 816,50 40 821))
>>>>> 30 | POLYGON Z ((40 30 814,50 30 816,40 40 800,40 30 814))
>>>>> 31 | POLYGON Z ((30 30 817,30 40 816,20 40 807,30 30 817))
>>>>> (32 rows)
>>>>> select st_astext(geomtext) from vfaces;
>>>>> st_astext
>>>>> POLYGON Z ((51 17.8 799,9 38.8 799,9 51 819.33333333333,19.4 51
>>>>> 828,51 35.2 828,51 17.8 799))
>>>>> POLYGON Z ((51 17.8 799,9 38.8 799,9 51 799,51 51 799,51 17.8 799))
>>>>> POLYGON Z ((51 35.2 828,19.4 51 828,51 51 828,51 35.2 828))
>>>>> POLYGON Z ((9 9 799,9 38.8 799,51 17.8 799,51 9 799,9 9 799))
>>>>> POLYGON Z ((9 9 828,9 51 828,19.4 51 828,51 35.2 828,51 9 828,9 9
>>>>> 828))
>>>>> (6 rows)
>>>>> *select distinct a.id
>>>>> from small_tris a, vfaces b
>>>>> where st_intersects (a.geomtext, b.geomtext)
>>>>> order by a.id;*
>>>>> id
>>>>> 0
>>>>> 1
>>>>> 2
>>>>> 3
>>>>> 4
>>>>> 5
>>>>> 6
>>>>> 7
>>>>> 8
>>>>> 9
>>>>> 10
>>>>> 11
>>>>> 12
>>>>> 13
>>>>> 14
>>>>> 15
>>>>> 16
>>>>> 17
>>>>> 18
>>>>> 19
>>>>> 20
>>>>> 21
>>>>> 22
>>>>> 23
>>>>> 24
>>>>> 25
>>>>> 26
>>>>> 27
>>>>> 28
>>>>> 29
>>>>> 30
>>>>> 31
>>>>> (32 rows)
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20121030/e1324032/attachment.html>
