[postgis-users] Retrieving linestring data between endpoints
Max Pyziur pyz at brama.com
Wed Sep 5 10:15:38 PDT 2012
Greetings,
I'm trying to figure out a way of constructing linestrings between
endpoints.
Shapefile data for pipelines and railroads does not present continuous
lines; instead they are in the form of small line segments. The
applications are using data for roads, pipelines, or railroads.
Interstate 70 is not one complete linestring between Washington DC and the
middle of Utah; instead it is a series of segments. The same with pipeline
and railroad data.
The problem becomes more cumbersome (at least to me) when there is no
knowledge of the data between two points (say Edmonton and Vancouver) and
you want to see if there is a way to string a set of segments between two
points (to answer a question like is there a railline between Edmonton and
Vancouver)?
I would appreciate any advice on how to proceed.
Much thanks,
Max Pyziur
pyz at brama.com
