On Friday 07 September 2012, Sandro Santilli wrote: > If you hard-code, try including the ".so" suffix. > Also see if ``ldd /usr/lib/pgsql/postgis-1.5.so`` works > (and gives you no 'not found'). Thanks for reply, but I solved the problem. -- Regards, Sergey
