[postgis-users] RE : PostGIS 2.0 Raster Mosaic...
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Mon Sep 10 11:22:42 PDT 2012
Why did you remove the -F option in the second command? You're trying to append less columns in an existing table.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of Brian Fitzgerald
> Sent: Monday, September 10, 2012 1:13 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] RE : PostGIS 2.0 Raster Mosaic...
> Here is what I tried without luck:
> Step 1 : ./raster2pgsql -s 2273 -t 256x256 -F -I
> /home/rcgeoadmin/temp/979903.tif public.testmosaic >
> /home/rcgeoadmin/temp/979903mosaic.sql
> Step 2: psql -d mydb -f 979903mosaic.sql
> Step 3: ./raster2pgsql -s 2273 -t 256x256 -a
> /home/rcgeoadmin/temp/979801.tif public.testmosaic >
> /home/rcgeoadmin/temp/979801mosaic.sql
> Step 4: psql -d mydb -f 979801mosaic.sql
> On Mon, Sep 10, 2012 at 12:02 PM, Francois Hugues
> <hugues.francois at irstea.fr> wrote:
> I may be wrong but I think the problem comes from the index. You use
> the option -I to create it but you cannot create it more than once. You should
> just remove the -I option from the second time you use your command and I
> think it should work.
> Hugues.
> -------- Message d'origine--------
> De: postgis-users-bounces at postgis.refractions.net de la part de Brian
> Fitzgerald
> Date: lun. 10/09/2012 17:57
> À: PostGIS Users Discussion
> Objet : [postgis-users] PostGIS 2.0 Raster Mosaic...
> ... trying to create a raster mosaic using the raster2pgsql tool... I
> imported a tif image and now I want to append a second adjacent tiff to
> the
> first one... figured I could just run the same command with -F -I -t
> 256x256 etc and tack on the -a? I tried this and got an error saying:
> 'testmosaic_raster_gist' already exists... anyone know how to
> accomplish
> this?
> - Brian
> Brian Fitzgerald, PMP, GISP
> bkfitz at gmail.com
> 803.426.3469
> postgis-users mailing list
> bkfitz at gmail.com
> 803.426.3469
