[postgis-users] RE : PostGIS 2.0 Raster Mosaic...
Brian Fitzgerald
bkfitz at gmail.com
Tue Sep 11 09:43:32 PDT 2012
Well if I leave the -F and -I in, I get the following error when I run the
.sql:
psql:979801mosaic.sql:2: ERROR: relation "testmosaic" already exists.
Here is what I ran:
rcgeoadmin at minty ~/src/postgis-2.0.1/raster/loader $ ./raster2pgsql -s 2273
-t 256x256 -F -I /home/rcgeoadmin/temp/979903.tif public.testmosaic >
/home/rcgeoadmin/temp/979903mosaic.sql
Processing 1/1: /home/rcgeoadmin/temp/979903.tif
-t 256x256 -F -I /home/rcgeoadmin/temp/979801.tif public.testmosaic >
/home/rcgeoadmin/temp/979801mosaic.sql
Processing 1/1: /home/rcgeoadmin/temp/979801.tif
On Mon, Sep 10, 2012 at 2:22 PM, Pierre Racine
<Pierre.Racine at sbf.ulaval.ca>wrote:
> Why did you remove the -F option in the second command? You're trying to
> append less columns in an existing table.
> > -----Original Message-----
> > From: postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-
> > bounces at postgis.refractions.net] On Behalf Of Brian Fitzgerald
> > Sent: Monday, September 10, 2012 1:13 PM
> > To: PostGIS Users Discussion
> > Subject: Re: [postgis-users] RE : PostGIS 2.0 Raster Mosaic...
> > Here is what I tried without luck:
> > Step 1 : ./raster2pgsql -s 2273 -t 256x256 -F -I
> > Step 2: psql -d mydb -f 979903mosaic.sql
> > Step 3: ./raster2pgsql -s 2273 -t 256x256 -a
> > Step 4: psql -d mydb -f 979801mosaic.sql
> > On Mon, Sep 10, 2012 at 12:02 PM, Francois Hugues
> > <hugues.francois at irstea.fr> wrote:
> > I may be wrong but I think the problem comes from the index. You
> use
> > the option -I to create it but you cannot create it more than once. You
> should
> > just remove the -I option from the second time you use your command and I
> > think it should work.
> > Hugues.
> > -------- Message d'origine--------
> > De: postgis-users-bounces at postgis.refractions.net de la part de
> Brian
> > Fitzgerald
> > Date: lun. 10/09/2012 17:57
> > À: PostGIS Users Discussion
> > Objet : [postgis-users] PostGIS 2.0 Raster Mosaic...
> > ... trying to create a raster mosaic using the raster2pgsql
> tool... I
> > imported a tif image and now I want to append a second adjacent
> tiff to
> > the
> > first one... figured I could just run the same command with -F -I
> -t
> > 256x256 etc and tack on the -a? I tried this and got an error
> saying:
> > 'testmosaic_raster_gist' already exists... anyone know how to
> > accomplish
> > this?
> > - Brian
> > Brian Fitzgerald, PMP, GISP
> > bkfitz at gmail.com
> > 803.426.3469
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> > bkfitz at gmail.com
> > 803.426.3469
bkfitz at gmail.com
803.426.3469
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120911/f02478fa/attachment.html>
