[postgis-users] RE : Postgis 3 dimension geometry table
Francois Hugues
hugues.francois at irstea.fr
Fri Sep 14 02:41:01 PDT 2012
Hello,
I'm not sure to understand your question.
Did you try psql2shp ?
You could also take a look to openjump, qgis or arcgis where you can add a query layer and then export it to shp.
Hugues.
-------- Message d'origine--------
De: postgis-users-bounces at postgis.refractions.net de la part de francescoboccacci at libero.it
Date: ven. 14/09/2012 10:47
À: postgis-users at postgis.refractions.net
Objet : [postgis-users] Postgis 3 dimension geometry table
Hi all,
i have a question for you. I have a table with these properties:
CONSTRAINT enforce_dims_geometry CHECK (st_ndims(geometry) = 3),
CONSTRAINT enforce_geotype_geometry CHECK (geometrytype(geometry) =
'MULTILINESTRING'::text OR geometry IS NULL),
i would like to export that table in shapefile or kml format (or any external
format) but i don't find a good tool to do that.
Can you help me?Is there a way to do that?
Francesco
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120914/9426a6a7/attachment.bin>
