[postgis-users] upload a folder of raster files
    Pierre Racine
    Pierre.Racine at sbf.ulaval.ca
    Fri Sep 14 11:34:18 PDT 2012
If all your rasters have the same footprint the extent geometry should be the same.
Pierre
> -----Original Message-----
> From: Giannis Giakoumidakis [mailto:ggiakoumidakis at yahoo.com]
> Sent: Friday, September 14, 2012 12:02 PM
> To: Pierre Racine; PostGIS Users Discussion
> Subject: Re: [postgis-users] upload a folder of raster files
> Ok I created the QueryTables and I made the select to Add contraints to each
> table.
> One last question: I see no differences in the "extent geometry" column of the
> "raster_columns" view between all the tables I created, it is exactly the same in
> all. It seems like it is the same raster in every table, with different name. It
> shouldn't have every table different geometry or it is right the way it is now?
> ________________________________
> From: Pierre Racine <Pierre.Racine at sbf.ulaval.ca>
> To: Giannis Giakoumidakis <ggiakoumidakis at yahoo.com>; PostGIS Users
> Discussion <postgis-users at postgis.refractions.net>
> Sent: Tuesday, September 11, 2012 8:51 PM
> Subject: RE: [postgis-users] upload a folder of raster files
> > Anyway, I need all the information missing from these
> > tables, to make queries. I guess there is no way to add contraints and
> geometry
> > to all after the split. Is there any way that the splitted tables can hold all the
> > information from the main table during the split? I think no. What's your
> > opinion?
> You should just read all the blog post. I explain how to add the constraints on all
> the tables.
> Pierre
