[postgis-users] join of topogeo_AddLineString() output
Wim Nederend
wim.nederend at and.com
Tue Sep 18 06:50:06 PDT 2012
I want to do something with the edges returned by topogeo_AddLineString()
(I'm not a very experienced Postgres user).
I would expect the following to be working
for input_rec in
select foo.x from
(select topogeo_AddLineString('wimpy', geomvar) as x) as foo
inner join edge_data as e
on e.edge_id = foo.x
loop
raise notice 'faces: % %', input_rec.left_face,
input_rec.right_face;
end loop;
But I get no output.
Following code does work, but looks a bit clumsy to me:
select array_agg(x) into edges from
( select topogeo_AddLineString('wimpy', geomvar) as x) as foo;
--raise notice 'edges %', edges;
for input_rec in
select e.left_face, e.right_face, e.edge_id
from edge_data as e
where edge_id = any(edges)
loop
end loop;
Does anyone have a suggestion for me?
Regards, Wim
