[postgis-users] raster loading and ST_Value performance
Phil Hurvitz
phurvitz at uw.edu
Tue Sep 18 18:11:32 PDT 2012
Hello PostGIS raster experts,
I have loaded a raster representing slope for an area of Washington
State (USA). The source was a large Imagine (img/ige) file (about 4.3
GB, 31935 x 34649 pixels at 10 m pixel size), which I copied to the db
using
raster2pgsql -I -C -e -Y -F -d -s 2926 -t 1000x1000 slope_ps.img
gis.slope | psql dbname
I used the tiling of 1000x1000 after numerous attempts to load the
raster without tiling, and using several different file types (TIFF,
ArcInfo grid, ArcInfo ASCII), each of which caused a Segmentation
Error/Core dump.
Now that I have a working raster, I can get a single point value using
this query:
SELECT rid,
ST_Value(rast, the_geom, false) FROM slope,
(SELECT the_geom FROM twins_withn_wa LIMIT 1) AS foo;
rid | st_value
589 | 8.1965799331665
(1120 rows)
Time: 4768.648 ms
4 s seems like a long time to get one value from a raster. Here is the
output of EXPLAIN ANALYZE, which seems to show that the nested loop is
taking most of the time:
QUERY PLAN
Nested Loop (cost=0.00..312.67 rows=1120 width=164) (actual
time=7.604..4736.852 rows=1120 loops=1)
-> Limit (cost=0.00..0.26 rows=1 width=128) (actual
time=0.005..0.005 rows=1 loops=1)
-> Seq Scan on twins_withn_wa (cost=0.00..3043.02 rows=11702
width=128) (actual time=0.004..0.004 rows=1 loops=1)
-> Seq Scan on slope (cost=0.00..21.20 rows=1120 width=36) (actual
time=0.004..0.890 rows=1120 loops=1)
Total runtime: 4737.278 ms
(5 rows)
I am running on a fairly beefy RHEL 6.3 machine with 16 G RAM (8 GB
allocated to PostgreSQL), PostGIS 2.0.1 on PostgreSQL 9.1.1:
select postgis_full_version();
POSTGIS="2.0.1 r9979" GEOS="3.3.5-CAPI-1.7.5" PROJ="Rel. 4.7.1, 23
September 2009" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.6" RASTER
(1 row)
select version();
version
PostgreSQL 9.1.1 on x86_64-unknown-linux-gnu, compiled by gcc (GCC)
4.4.5 20110214 (Red Hat 4.4.5-6), 64-bit
(1 row)
I have two questions:
Q1: What effect does different tile size have on storage and performance?
Q2: We will need to be getting raster values from a large number of
point tables over a large number of raster tables. Is there any method
to speed up the queries?
Any pointers will be greatly appreciated!
-P.
Philip M. Hurvitz, PhD | Research Assistant Professor | UW-CBE
Urban Form Lab | 1107 NE 45th Street, Suite 535 | Box 354802
University of Washington, Seattle, Washington 98195-4802, USA
phurvitz at u.washington.edu | http://gis.washington.edu/phurvitz
"What is essential is invisible to the eye." -de Saint-Exupéry
