[postgis-users] field type "public.geometry"
Bborie Park
bkpark at ucdavis.edu
Thu Sep 20 15:31:26 PDT 2012
That would be because the schema "public" isn't in that user's
"search_path". The following will show the current session's search_path.
SHOW search_path;
-bborie
On 09/20/2012 02:54 PM, Phil Hurvitz wrote:
> Hi, one of our users has some tables that show geometry fields as type
> "public.geometry," e.g.,
> Column | Type | Modifiers
> ogc_fid | integer | not null
> the_geom | public.geometry |
> whereas they used to have more "normal" types, e.g.,
> ogc_fid | integer |
> the_geom | geometry(Geometry,2926) |
> I don't know what might have caused this; the data in the field do not
> seem to have changed, but the field as it is has limited functionality.
> Can someone suggest a fix? Thanks,
> -P.
> Philip M. Hurvitz, PhD | Research Assistant Professor | UW-CBE
> Urban Form Lab | 1107 NE 45th Street, Suite 535 | Box 354802
> University of Washington, Seattle, Washington 98195-4802, USA
> phurvitz at u.washington.edu | http://gis.washington.edu/phurvitz
> "What is essential is invisible to the eye." -de Saint-Exupéry
> postgis-users mailing list
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
