[postgis-users] Navteq import
Francois Hugues hugues.francois at irstea.fr
Fri Sep 21 03:42:19 PDT 2012
Hello,
Do you have a unique id ? The problem could be here.
You should also try with openjump.
Hugues.
-------- Message d'origine--------
De: postgis-users-bounces at postgis.refractions.net de la part de "Benjamin Rückert"
Date: ven. 21/09/2012 12:29
À: postgis-users at postgis.refractions.net
Objet : [postgis-users] Navteq import
Hello,
Has someone experience with Navteq RDF data?
I've loaded the europe data in postgresql/postGIS via RDF installer (part of rdf viewer). I ve tried to visualize the Data in ArcGIS and QGIS but it was not possible to connect the database because of the index data type (bigint).
Has someone an idea to get rid of the problem? Are there any Opensource solutions for visualization RDF data (imported in Postgresql)?
Which steps I have to pass through after the import for getting a spatial enable database?
Thank you for your reading and hopefully answering?
Ben
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120921/0d9925de/attachment.bin>
