[postgis-users] Selecting which table column to update
Francois Hugues
hugues.francois at irstea.fr
Mon Sep 24 11:32:58 PDT 2012
Hello,
There are a lot of syntax error in your query : the "=" with nothing, the use of case for many columns, the lack of from before your subselect. Hard to say what is the error and what exactly you want to do (at least for me) without knowledge of how your data is made.
I don't understand what value you want to write in the updated column but I am not sure you need to use case but something like this could be ok :
update pipe
set branch_right_id = bob.edge_data.edge_id
from (
select bob.edge_data.edge_id
from bob.edge_data, num_search, pipe
where st_intersects(bob.edge_data.geom, num_search.the_geom9)) --intersection of max edge collected in pipe table
and pipe.id = 10
) as foo
where st_centroid(bob.edge_data.geom) >> num_search.the_geom9
and bob.edge_data.edge_id <> pipe.edge
and pipe.id =10
Remember that what you do when you run an update query can not be undone unless you have a save of your original data.
Hugues.
-------- Message d'origine--------
De: postgis-users-bounces at postgis.refractions.net de la part de Bob Pawley
Date: lun. 24/09/2012 19:42
À: postgis-users at postgis.refractions.net
Objet : [postgis-users] Selecting which table column to update
Hi
I am attempting to update a table column that is to be determined by a linestring being above, below or to the right of an intersection.
update pipe
set
case when st_centroid(bob.edge_data.geom) >> num_search.the_geom9
where bob.edge_data.edge_id <> pipe.edge
and pipe.id =10
then branch_right_id =
when st_centroid(bob.edge_data.geom) |>> num_search.the_geom9
and pipe.id =10
then branch_up_id =
when st_centroid(bob.edge_data.geom) <<| num_search.the_geom9
and pipe.id =10
then branch_down_id =
end
(select bob.edge_data.edge_id
where pipe.id = 10;
Following is the error-
ERROR: syntax error at or near "case"
LINE 3: case when st_centroid(bob.edge_data.geom) >> num_search.the...
Can this be done?
Bob
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120924/8ecd5f32/attachment.bin>
