[postgis-users] 3D topology nodes?
Sandro Santilli
strk at keybit.net
Tue Sep 25 23:58:16 PDT 2012
On Tue, Sep 25, 2012 at 12:27:48PM -0700, akoel wrote:
> Hi Sandro
> I got the same error as John did. ("Geometry has Z dimension, but column
> does not.")
> As you advised, I checked the CreateTopology function but I did not find
> anything about Z value.
> Would you be more specific about it, please?
http://postgis.refractions.net/documentation/manual-svn/CreateTopology.html
See "hasZ" parameter.
If you want more specific help you have to be more specific about the problem.
You mention the error you get but not the query you were running.
--strk;
http://www.cartodb.com - Map, analyze and build applications with your data
~~ http://strk.keybit.net
