[postgis-users] 3D topology nodes?
akoel akoel at freemail.hu
Wed Sep 26 05:59:27 PDT 2012
Oh, thanks a lot. I overlooked this detail.
 "Sandro Santilli [via PostGIS]" <ml-node+s17n5000032h18 at n6.nabble.com> írta:
>On Tue, Sep 25, 2012 at 12:27:48PM -0700, akoel wrote:
>> Hi Sandro
>> I got the same error as John did. ("Geometry has Z dimension, but column
>> does not.")
>> As you advised, I checked the CreateTopology function but I did not find
>> anything about Z value.
>> Would you be more specific about it, please?
>http://postgis.refractions.net/documentation/manual-svn/CreateTopology.html
>See "hasZ" parameter.
>If you want more specific help you have to be more specific about the problem.
>You mention the error you get but not the query you were running.
>--strk;
> http://www.cartodb.com - Map, analyze and build applications with your data
>                                       ~~ http://strk.keybit.net
>_______________________________________________
>postgis-users mailing list
>[hidden email]
>http://postgis.refractions.net/mailman/listinfo/postgis-users
>If you reply to this email, your message will be added to the discussion below:http://postgis.17.n6.nabble.com/3D-topology-nodes-tp4997926p5000032.htmlTo unsubscribe from 3D topology nodes?, click here.
>NAML
View this message in context: http://postgis.17.n6.nabble.com/3D-topology-nodes-tp4997926p5000035.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120926/1407708d/attachment.html>
