[postgis-users] Debian Squeeze - no xml support for Pg 9.2
Volkmar Herbst volkmar.herbst at gmx.de
Wed Sep 26 09:22:22 PDT 2012
Hi all,
I have a problem with xml support on a fresh installation of pg 9.2. I
configures and build postgres with xml.
I rebuild with /usr/local/pgsql/postgresql-9.2.0/configure --with-libxml
--with-python. Configuring make and make install went well.
configure: using CFLAGS=-O2 -Wall -Wmissing-prototypes -Wpointer-arith
-Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute
-Wformat-security -fno-strict-aliasing -fwrapv
configure: using CPPFLAGS= -D_GNU_SOURCE -I/usr/include/libxml2
configure: using LDFLAGS=  -Wl,--as-needed
However I get an error in postgres doing xml operations:
select '<test></test>'::xml
results in
ERROR:  unsupported XML feature
LINE 1: select '<test></test>'::xml
DETAIL:  This functionality requires the server to be built with libxml
support.
HINT:  You need to rebuild PostgreSQL using --with-libxml.
********** Error **********
SQL state: 0A000
Detail: This functionality requires the server to be built with libxml
support.
Hint: You need to rebuild PostgreSQL using --with-libxml.
Character: 8
Pg_config gives:
BINDIR = /usr/local/pgsql/bin
DOCDIR = /usr/local/pgsql/share/doc
HTMLDIR = /usr/local/pgsql/share/doc
INCLUDEDIR = /usr/local/pgsql/include
PKGINCLUDEDIR = /usr/local/pgsql/include
INCLUDEDIR-SERVER = /usr/local/pgsql/include/server
LIBDIR = /usr/local/pgsql/lib
PKGLIBDIR = /usr/local/pgsql/lib
LOCALEDIR = /usr/local/pgsql/share/locale
MANDIR = /usr/local/pgsql/share/man
SHAREDIR = /usr/local/pgsql/share
SYSCONFDIR = /usr/local/pgsql/etc
PGXS = /usr/local/pgsql/lib/pgxs/src/makefiles/pgxs.mk
CONFIGURE = '-with-python'
CC = gcc
CPPFLAGS = -D_GNU_SOURCE
CFLAGS = -O2 -Wall -Wmissing-prototypes -Wpointer-arith
CFLAGS_SL = -fpic
LDFLAGS = -Wl,--as-needed
-Wl,-rpath,'/usr/local/pgsql/lib',--enable-new-dtags
LDFLAGS_EX =
LDFLAGS_SL =
LIBS = -lpgport -lz -lreadline -lcrypt -ldl -lm
VERSION = PostgreSQL 9.2.0
Could anybody help?
Volkmar Herbst
Leisniger Chaussee 10
04769 Sornzig Ablaß
Tel.: 034362 30627
Mobil: 016098121740
Email: volkmar.herbst at gmx.de
