[postgis-users] Topology Postgis 2.0
Sandro Santilli
strk at keybit.net
Thu Sep 27 03:36:43 PDT 2012
On Thu, Sep 27, 2012 at 02:08:00AM -0700, ps.tiara wrote:
> oh thanks ..
> I almost gave up with my research ..
> I used geometry that are two adjacent objects imported from KML, and I have
> not managed to make the topology, do you think it is possible to do a
> topology?
Sure, it should. How did you try, what error did you get, which version
are you running and can you share the data ?
--strk;
http://www.cartodb.com - Map, analyze and build applications with your data
~~ http://strk.keybit.net
