[postgis-users] unique id in QGIS/PostGIS
Margie Roswell
mroswell at gmail.com
Sun Apr 7 07:35:45 PDT 2013
Thanks very much. I like the idea of scripting these routine behaviors.
1. I figured out that the correct CRS is
http://spatialreference.org/ref/epsg/4019/
It basically says (in QGIS)
Unknown datum based upon the GRS 1980 ellipsoid EPSG:4019
but it does exactly match the PRJ file for legislative_final shapefile.
A friend suggests using Maryland State Plan, so, I'll likely switch that
command to
shp2pgsql -s 3559:26985 -I $SHP legislative_final | psql -d test
2. I do have access to a PostGIS install on a mac or an EC2, but right now
my preferred environment is windows, with my large screen, and special
wrist-friendly keyboard.* So, I'm going to have to figure out how to run
this script.* (or even how run anything from the command line on the
windows side.)
If anyone has some insight into how to run or replicate a bash script on a
windows installation, let me know. The* psql tool that comes with windows
starts right inside a database*, so I haven't actually yet figured out how
to even run a simple postgres command on the windows side. No success from
either the SQL shell or the regular windows command prompt.
The scripting approach:
- offers helpful comments to remind us of the data source.
- offers a record of exactly what we did. (Part of the reason I've been
using PgAdmin III is that I have appreciated the history file there.)
Since I like this scripting approach, I'm off to try to figure out how to
do it on the windows side.... Is anyone here running postgres on windows,
with command line success?
Margie
http://FarmBillPrimer.org
http://www.BaltimoreUrbanAg.org (Please send events; This site is hungry.)
http://www.ExcellentNutrition.org
http://www.packtpub.com/drupal-5-views-recipes/book
On Sat, Apr 6, 2013 at 6:37 PM, <pcreso at pcreso.com> wrote:
> Hi again,
> In your screencap your SRID seems to be set to zero. Even if the data
> displays in QGIS, it will not be in the correct place, unless you have this
> set correctly. So with the unique index/prikary key - you still probably
> won't see the data unless you zoom the that layer extent.
> I have scribbled out a quick Linux script which uses the shp2pgsql command
> to load the shapefile, & which creates the unique index automatically...
> I'm not certain I got the SRID correct - so it will be worth checking.
> HTH,
> Brent Wood
> #! /bin/bash
> # script to load Legislative_shape.zip & create unique index
> SHP=Legislative_final_shapefile/Legislative_Final.shp
> # create new, empty Postgres database
> dropdb test
> createdb test
> # install postgis
> psql -d test -c "create extension postgis;"
> # determine projection
> # assume from these links that the SRID is 3559 -
> # I couldn't find one to match the prj file directly
> # http://planning.maryland.gov/msdc/S5_Map_GIS.shtml
> # http://www.spatialreference.org/ref/sr-org/3559/
> # load the shapefile the easy way...
> # use -I to create the primary key
> shp2pgsql -s 3559 -I $SHP legislative_final | psql -d test
> --- On *Sat, 4/6/13, Margie Roswell <mroswell at gmail.com>* wrote:
> From: Margie Roswell <mroswell at gmail.com>
> Subject: [postgis-users] unique id in QGIS/PostGIS
> To: "PostGIS Users Discussion" <postgis-users at lists.osgeo.org>
> Date: Saturday, April 6, 2013, 9:18 PM
> I've been googling up a storm, now that I've got a local postgis database
> with QGIS. But still haven't figured out how to display a newly created
> table.
> The query I used to create the table:
> CREATE TABLE smaller_leg_final AS
> SELECT ST_Buffer(geom,-500) AS geom, legislative_final.district
> FROM legislative_final
> WHERE area > 30;
> I then discovered that I needed a unique ID, and did the following:
> ALTER TABLE smaller_leg_final ADD COLUMN id serial not null;
> This successfully populated the ID field with unique integers.
> However when I go into QGIS, the Primary Key column offers no options.
> when I click into it, it just asks me to choose an SRID, which I believe
> I've already done. The table loads, but nothing displays.
> I honestly feel a bit like a toddler given ice skates and placed on an icy
> rink. I'm toddling my way around, falling, getting back up, and then
> looking up and asking: why did I fall?
> Once upon a time I was at the true cutting edge of GIS... I purchased
> MapInfo versions 1.1, and upgraded from there for many years. Moving into
> QGIS/Posgres/postGIS now, and well on the path to success, but .... not...
> quite... there.
> Are there any QGIS users here who can help me to display my new table?
> Do I need a different postgres statement? Is there a different field name
> expected? Maybe my query generated invalid shapes... But still, the geom
> field is displaying in the "Add PostGIS layers "Geometry column", but the
> Primary key column option doesn't allow me to select my 'id' field.
> Insight welcome.
> On Thu, Apr 4, 2013 at 11:21 AM, Lelo - Luiz Rogério De Pieri <
> lelo.pieri at gmail.com <http://mc/compose?to=lelo.pieri@gmail.com>> wrote:
> Hi all,
> I'm having a problem to execute a pgsql2shp command using java.
> My OS is Ubuntu and it's frequently I use to generate shp files using
> pgsql2shp, but now I want to do it through java.
> The follow command works fine on terminal
> pgsql2shp -f pontos_05600202_teste -h myhost -u myuser -P mypasswd -g
> coordinates my_database "SELECT * from points where id_uploaded_file =
> 37995";
> Now I'm trying to execute the follow code:
> ProcessBuilder pb = new ProcessBuilder("pgsql2shp", "-f
> pontos_05600202_teste", "-h myhost", "-u myuser", "-P mypasswd", "-g
> coordinates", "my_database", "SELECT coordinates, date from points where
> id_uploaded_file = 37995");
> Process proc;
> proc = pb.start();
> InputStream stdin = proc.getInputStream();
> InputStreamReader isr = new InputStreamReader(stdin);
> BufferedReader br = new BufferedReader(isr);
> String line = null;
> System.out.println("<OUTPUT>");
> while ((line = br.readLine()) != null)
> System.out.println(line);
> System.out.println("</OUTPUT>");
> int exitVal = proc.waitFor();
> System.out.println("Process exitValue: " + exitVal);
> And the result is:
> <OUTPUT>
> Preparing table for user query... Done.
> Initializing... coordinates: no such attribute in table
> __pgsql2shp14493_tmp_table
> </OUTPUT>
> Does anybody as any idea about it?
> Thank you for all
> Best regards
> Rogério De Pieri (Lelo)
> SCJP 5
> Buscando melhorar a cada dia
> Áudio, Hardware & Software
> www.twitter.com/lelopieri
> blogdolelo.wordpress.com
> postgis-users mailing list
> postgis-users at lists.osgeo.org<http://mc/compose?to=postgis-users@lists.osgeo.org>
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> -----Inline Attachment Follows-----
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130407/d5739802/attachment.html>
