[postgis-users] Vote: PAGC address standardizer in extras
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Apr 9 07:46:26 PDT 2013
+1
I will shortly have a new folder in my PAGC branch for postgresql that
contains all the required files and a PGXS Makefile. This should greatly
simplify releasing this as an extension or forking it into another
project. This code is already a fork of the PAGC code in spite of being
in the PAGC tree because I had to do major slash and burn to extract
this code into a standalone module that did not drag in all of PAGC.
-Steve
On 4/7/2013 12:36 AM, Paragon Corporation wrote:
> I would like at some point (soon) fork the standardizer part of pagc and
> include in extras/pagc_standardizer folder of PostGIS to make it easier to
> install as part of the PostGIS build.
> I'd like a vote on this (PSC, developers, and general users)
> As discussed here
> http://trac.osgeo.org/postgis/ticket/2193
> As some folks have noticed, I've been working on changing the tiger geocoder
> to use an alternative address standardizer which is part of the PAGC library
> (MIT Licensed).
> This unfortunately will require additional library compile in C, but the way
> I have it structured, this piece is not mandatory to use the tiger geocoder
> The logic to use as a drop in replacement is there but not documented since
> still working out some kinks.
> Steve Woodbridge broke out just the standardizer part as a postgresql
> extension and was discussed
> On postgis-users discussion a while back
> http://lists.osgeo.org/pipermail/postgis-users/2012-December/036019.html
> The purpose is:
> 1)
> The PAGC does generally a better job of standardizing than the built in
> tiger geocoder one so will resolve many of complaints people have had
> 2) Provide a standardizer separate from tiger geocoder that we can reuse for
> other PostGIS based geocoders
> As such the standardizer will be documented in PostGIS documentation
> describing how to build and enable in tiger geocoder
> And how to use it separate from tiger geocoder.
> 3) Should be generally faster too once we work out some issues on how its
> called and its ability to cache the C built standardizer object.
> Thoughts, concerns
> Thanks,
> Regina
> http://www.postgis.us
> http://postgis.net
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
