[postgis-users] unique id in QGIS/PostGIS
pcreso at pcreso.com pcreso at pcreso.com
Tue Apr 9 09:46:57 PDT 2013
Hi Margie,
Try:
export PATH=/usr/local/bin:/cygdrive/c/Program\ Files/PostgreSQL/9.2/bin
echo $PATH
then
which psql
and note - there is no command "postgres"
Brent
--- On Tue, 4/9/13, Margie Roswell <mroswell at gmail.com> wrote:
Subject: Re: [postgis-users] unique id in QGIS/PostGIS
To: "Greg Williamson" <gwilliamson39 at yahoo.com>, "PostGIS Users Discussion" <postgis-users at lists.osgeo.org>
Date: Tuesday, April 9, 2013, 3:42 PM
Thanks so much for responding
At this point, I've fiddled so much with the PATH, I'm nowhere. Can't even run that log command you suggested.
So, I'm really curious: what environments are people working in? SSH to remote Ubuntu, like E2? macboook? Anyone having success scripting on the windows side?
I had hoped to have my desktop also serve as my local dev environment for postgres/postgis/qgis/tilemill...  I'm pretty much there, except on the windows side I could only use the GUI, and so far no luck on the command line side of things.... and the latter was offered as a solution to some of the barriers I was experiencing.
The space in "Program Files" is an issue, and escaping it doesn't seem to work. Neither does quoting it. I've done a bunch of googling, and maybe I'm just too tired to get there tonight.
owner at owner-PC ~/src
$ PATH=/usr/local/bin:`/cygdrive/c/Program\ Files/PostgreSQL/9.2/bin`
-bash: /cygdrive/c/Program Files/PostgreSQL/9.2/bin: is a directory
$ export PATH
$ $PATH
-bash: /usr/local/bin:: No such file or directory
$ postgres log
-bash: postgres: command not found
http://FarmBillPrimer.orghttp://www.BaltimoreUrbanAg.org (Please send events; This site is hungry.)
http://www.ExcellentNutrition.org
http://www.packtpub.com/drupal-5-views-recipes/book
On Mon, Apr 8, 2013 at 11:25 PM, Greg Williamson <gwilliamson39 at yahoo.com> wrote:
Margie --
What does the postgres log say b?
If it showsnothing the attempt to connect never made it to the postgres port (usually 5432 but I don't inow what Windows might be using for a local connection).
If it did make the basix handshake, the log message might show an authentication issue or other useful tidbit.
People with more windows experience might tell you where to look for the log and what to tweak on the config side to allow connections locally.
Greg Williamson
 To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
 Sent: Monday, April 8, 2013 7:27 PM
This thread morphed from a QGIS issue to a configuration and scripting and environment issue. I'm fine with that... if I get
 a comfortable working environment, I'll be ready to tackle other learning curves... so now I'll report my struggles on this "environment" front.
First, I might mention that I'm actually generally competent in a linux environment. Command line, no problem. And usually I can routinely edit files in vim, for instance, but I'll have to figure out a slew of key bindings to make vim remotely usable now that I'm in windows Not a problem, I've got Sublime Text 2. So, ignoring that issue the need-sensible vim-key-bindings issue for now.
I'm choosing windows because it's where my comfortable keyboard is, my large monitor, my desk. Little macbook laptop can't compete on this front. (I'll consider another system, if I totally strike out on the windows side... but hoping for one desk, one desktop.)
Biggest issue now is basically 'hello world'. My GUI interface was working... but now on the Cygwin side, I've got this. (I'm copying from the postgres documentation, because the error matches:
createdb: could not connect to database template1: could not connect to server:
        Is the server running locally and accepting
        connections on Unix domain socket "/tmp/.s.PGSQL.5432"?
This means that the server was not started, or it was not started where createdb expected it. Again, check the installation instructions or consult the administrator.
----------------------------------So, I'm really at ground zero on the cygwin side of things. I've got ;C:\Program Files\PostgreSQL\9.2\bin in my path. So, I'm not sure how to start the server.
And I've also added to bash path (without success here) http://stackoverflow.com/questions/4918830/how-can-i-set-my-cygwin-path-to-find-javac
owner at owner-PC ~/src$ export PATH=$PATH:/cygdrive/c/Program\ Files/PostgreSQL/9.2/bin
owner at owner-PC ~/src$ $PATH-bash: /usr/local/bin:/cygdrive/c/Program: No such file or directory
and lots of variations.
Sorry, so long. This is just all an earnest way of asking: what do I do to get past the
        connections on Unix domain socket "/tmp/.s.PGSQL.5432"?error?
Margie
P.S.
My goal was to place random dots, in legislative districts, 1, 2, or 3, as appropriate. No problem, QGIS makes that easy. But basically I wanted an internal buffer for each district shape, because I didn't like how close to the edge those dots were appearing. and that's when my trouble began. despite an accurate buffer statement, the map refused to show. So, a few days ago, I was on a far more advanced part of the learning curve, and now, trying to get an environment that'll run a script... or even just run ANY postgres command.
On Sun, Apr 7, 2013 at 8:39 PM, Stephen Mather <mather.stephen at gmail.com> wrote:
I would add to this that you can put different shapefiles into different tables:
for /r %%z in (*.dbf) do (%SHP2PGSQL%   -s 4326 -g geom -W "latin1" %%z %%~nz | %PSQL% )
where %~nz becomes the output tablename based on the name without extension of the input shapefile.
Also, if you don't want to run this as a batch file, but just run it on the command line, use a single percent:
for /r %z in (*.dbf) do (%SHP2PGSQL%   -s 4326 -g geom -W "latin1" %z %~nz | %PSQL% )
If you are interested in using PowerShell for this, it looks something like this:
$shapefile
= dir *.shp
$x
= 0
$shapefile
|foreach {
    write-host
($x++) "of $($shapefile.count) is started. $($_.Name) is processing"
    write-host
"shp2pgsql -s 4326 -g geom -W latin1 $($_.name)
$($_.basename) | psql"
I often write out all the flags I need for psql, so it might look more like this:
$shapefile
= dir *.shp
$x
= 0
$shapefile
|foreach {
    write-host
    write-host
$($_.basename) | psql -U postgres -d databasename -h localhost -p 5432"
Best,
Steve
On Sun, Apr 7, 2013 at 6:41 PM, Paragon Corporation <lr at pcorp.us> wrote:
Slight correction forgot the )
geom -W "latin1" %%z sometable | %PSQL% )
You can also chain
commands by using &
geom -W "latin1" %%z sometable | %PSQL% & %PSQL% -c "SELECT
postgis_full_version()" )
[mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Paragon
Corporation
Sent: Sunday, April 07, 2013 6:38 PM
To:
'PostGIS Users Discussion'
QGIS/PostGIS
You can also use msys mingw. We use the mingw64
chain which allows you to run linux shell scripts. That's what we use to
compile PostGIS for windows.
That aside, probably for what you want to do for
starters as Brent suggested, batch scripts are sufficient.
Our general batch script for loading up shape files
set
PGBIN=C:\Program Files\PostgreSQL\9.2\bin\
set PGPORT=5432
set
PGHOST=localhost
set PGUSER=postgres
set PGPASSWORD=something
set
PGDATABASE=mygisdb
set PSQL="%PGBIN%psql"
set
SHP2PGSQL="%PGBIN%shp2pgsql"
%SHP2PGSQL% -c -s 4326  -g geom   -W
"latin1" somefile.shp sometable | %PSQL%
If you
need to load up a whole bunch of files in a table you can use the  for do
batch command
for /r
sometable | %PSQL%
Hope
that helps,
Leo
and Regina
http://www.postgis.us
http://postgis.net
[mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Marjorie
Roswell
Sent: Sunday, April 07, 2013 2:37 PM
To:
Cc: postgis-users at lists.osgeo.org
Subject:
Thanks immensely. Some years ago on a different computer, I installed
cygwin.  Great reminder, and I appreciate it.  I'll be back at my
computer this evening.
Sent from my iPhone
On Apr 7, 2013, at 2:11 PM, pcreso at pcreso.com wrote:
      HI Margie,
I gave up on Windows as a productive
        computing environment last century, & have zero regrets about that
        these days, so I'm not the best person to offer Windows oriented help...
        however...
There are three ways to run scripts under Windows -
        Y
1. You can install Cygwin - which gives you a Linux-like
        environment within Windows, but is somewhat complicated & arcane.
        This does allow you to run the exact same bash scripts under Windows
        & Linux.
2. You can install Windows powershell & write
        your scripts using that "language":
http://technet.microsoft.com/en-us/scriptcenter/dd742419.aspx
3.
        You can write your scripts as batch files. Batch files are pretty
        limited, without text processing & other capabilities, but are
        probably able to do what you are looking to do right now. All Windows
        systems can run batch files with no additional software
        installed.
So, I'd suggest you look at batch files
        initially.
Google "batch file tutorial" & there are plenty to
        choose from, like http://www.chebucto.ns.ca/~ak621/DOS/BatBasic.html
 If
        you open a terminal window & type "psql -l" then press enter, you'll
        know if your path is already set up as they need to be. This is probably
        the only tricky thing you might need to configure. If it works, great,
        if not you'll need to add the folder containing the psql command to your
        path. If you do need to do this, see:
http://www.computerhope.com/issues/ch000549.htm
but
        it should be unecessary.
The simple shell script as a batch file
        - if I remember correctly
__________________________________________________________
REM
        script to load Legislative_shape.zip & create unique
        index
SHP=Legislative_final_shapefile\Legislative_Final.shp
REM
        create new, empty Postgres database
dropdb test
createdb
        test
REM install postgis
psql -d test -c "create extension
        postgis;"
REM determine projection
REM assume from these
        links that the SRID is 3559 -
REM   I couldn't find one to
        match the prj file directly
REM http://planning.maryland.gov/msdc/S5_Map_GIS.shtml
REM
        http://www.spatialreference.org/ref/sr-org/3559/
REM
        load the shapefile the easy way...
shp2pgsql -s 3559 -I %SHP%
        legislative_final | psql -d
        test
___________________________________________________________
Cheers,
        Brent
--- On Mon, 4/8/13, Margie Roswell <mroswell at gmail.com>
Subject:
To: pcreso at pcreso.com
Cc:
Date:
          Monday, April 8, 2013, 2:45 AM
          One step at a time. I figured out how to set the
          path in windows, to access psql
          So, next, to try to figure out how to script... (on the windows
          side)
          inching forward,
          Margie
          On Sun, Apr 7, 2013 at 10:35 AM,
          wrote:
          Thanks
            very much. I like the idea of scripting these routine
            behaviors.
1. I figured out that the correct CRS is
http://spatialreference.org/ref/epsg/4019/
It
            basically says (in QGIS)
Unknown datum based upon the GRS 1980
            ellipsoid EPSG:4019
but it does exactly match the PRJ file for
            legislative_final shapefile.
A friend suggests using Maryland
            State Plan, so, I'll likely switch that command to
shp2pgsql
            -s 3559:26985 -I $SHP legislative_final | psql -d test
2. I
            do have access to a PostGIS install on a mac or an EC2, but right
            now my preferred environment is windows, with my large screen, and
            special wrist-friendly keyboard. So, I'm going to have to figure
            out how to run this script. (or even how run anything from the
            command line on the windows side.)
If anyone has some insight
            into how to run or replicate a bash script on a windows
            installation, let me know. The psql tool that comes with windows
            starts right inside a database, so I haven't actually yet
            figured out how to even run a simple postgres command on the windows
            side. No success from either the SQL shell or the regular windows
            command prompt.
The scripting approach:
            - offers helpful comments to remind us of the data
            source.
            - offers a record of exactly what we did. (Part of the reason
            I've been using PgAdmin III is that I have appreciated the history
            file there.)
Since I like this scripting approach, I'm off to
            try to figure out how to do it on the windows side.... Is anyone
            here running postgres on windows, with command line
            success?
            Margie
            On Sat, Apr 6, 2013 at 6:37 PM,
            <pcreso at pcreso.com>
            wrote:
                  Hi again,
In your screencap your SRID
                    seems to be set to zero. Even if the data displays in QGIS,
                    it will not be in the correct place, unless you have this
                    set correctly. So with the unique index/prikary key - you
                    still probably won't see the data unless you zoom the that
                    layer extent.
I have scribbled out a quick Linux
                    script which uses the shp2pgsql command to load the
                    shapefile, & which creates the unique index
                    automatically... I'm not certain I got the SRID correct - so
                    it will be worth checking.
HTH,
  Brent
                    Wood
#! /bin/bash
# script to load
                    index
SHP=Legislative_final_shapefile/Legislative_Final.shp
dropdb
                    test
createdb test
# install postgis
psql -d
                    test -c "create extension postgis;"
# determine
                    projection
# assume from these links that the SRID is
                    3559 -
#   I couldn't find one to match the prj
                    file directly
# http://planning.maryland.gov/msdc/S5_Map_GIS.shtml
# use -I to create the
                    primary key
shp2pgsql -s 3559 -I $SHP legislative_final |
                    psql -d test
--- On Sat, 4/6/13, Margie Roswell <mroswell at gmail.com>
                    wrote:
Subject:
To: "PostGIS
Date:
                      Saturday, April 6, 2013, 9:18 PM
                      I've been googling up a storm, now that I've got a
                      local postgis database with QGIS. But still haven't
                      figured out how to display a newly created table.
The query I used to create the table:
                      CREATE TABLE
                      smaller_leg_final AS
SELECT ST_Buffer(geom,-500) AS
                      geom, legislative_final.district
FROM
                      legislative_final
WHERE area > 30;
I
                      then discovered that I needed a unique ID, and did the
                      following:
                      ALTER TABLE
                      smaller_leg_final ADD COLUMN id serial not
                      null;
This successfully populated the ID
                      field with unique integers.
However when I go into
                      QGIS, the Primary Key column offers no options. when I
                      click into it, it just asks me to choose an SRID, which I
                      believe I've already done. The table loads, but nothing
                      displays.
I honestly feel a bit like a toddler
                      given ice skates and placed on an icy rink. I'm toddling
                      my way around, falling, getting back up, and then looking
                      up and asking: why did I fall?
Once upon a time I
                      was at the true cutting edge of GIS... I purchased MapInfo
                      versions 1.1, and upgraded from there for many years.
                      Moving into QGIS/Posgres/postGIS now, and well on the path
                      to success, but .... not... quite... there.
Are
                      there any QGIS users here who can help me to display my
                      new table?
Do I need a different postgres
                      statement? Is there a different field name expected? Maybe
                      my query generated invalid shapes... But still, the geom
                      field is displaying in the "Add PostGIS layers "Geometry
                      column", but the Primary key column option doesn't allow
                      me to select my 'id' field.
Insight
                      welcome.
                      On Thu, Apr 4, 2013 at 11:21 AM, Lelo - Luiz Rogério
                      De Pieri <lelo.pieri at gmail.com>
                      wrote:
                        Hi all,
I'm having a problem to
                        execute a pgsql2shp command using java.
My
                        OS is Ubuntu and it's frequently I use to generate shp
                        files using pgsql2shp, but now I want to do it through java.
                        The follow command works fine
                        on terminal
pgsql2shp -f pontos_05600202_teste -h
                        myhost -u myuser -P mypasswd -g coordinates my_database
                        "SELECT * from points where id_uploaded_file =
                        37995";
                        Now I'm trying to execute the
                        follow code:
ProcessBuilder
                        pb = new ProcessBuilder("pgsql2shp", "-f
                        pontos_05600202_teste", "-h myhost", "-u myuser", "-P
                        mypasswd", "-g coordinates",
                        "my_database", "SELECT coordinates, date from points
                        where id_uploaded_file = 37995");
Process
                        proc;
proc = pb.start();
InputStream stdin =
                        proc.getInputStream();
InputStreamReader isr = new
                        InputStreamReader(stdin);
BufferedReader br = new
                        BufferedReader(isr);
String line =
                        null;
System.out.println("<OUTPUT>");
while
                        ((line = br.readLine()) != null)
                        System.out.println(line);
System.out.println("</OUTPUT>");
int
                        exitVal = proc.waitFor();
System.out.println("Process
                        exitValue: " + exitVal);
                        And the result is:
<OUTPUT>
Preparing
                        table for user query... Done.
Initializing...
                        coordinates:
                        no such attribute in table
                        __pgsql2shp14493_tmp_table
</OUTPUT>
                        Does anybody as any idea about it?
                        Thank you for all
Best regards
Rogério De Pieri  (Lelo)
                        SCJP 5
                        Buscando melhorar a cada dia
Áudio, Hardware
                        & Software
                        www.twitter.com/lelopieri
                        blogdolelo.wordpress.com
postgis-users
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
-----Inline
                      Attachment Follows-----
postgis-users
postgis-users mailing list
-----Inline Attachment Follows-----
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130409/6e2321ff/attachment.html>
