[postgis-users] Noob question with shp2pgsql
Jeff Lake
jeff at michiganwxsystem.com
Fri Apr 12 15:34:38 PDT 2013
try it without 'public',
at least that works for me on linux
*Jeff Lake K8JSL*
MichiganWxSystem <http://www.michiganwxsystem.com>
AllisonHouse <http://www.allisonhouse.com>
GRLevelXStuff <http://www.grlevelxstuff.com>
On 4/12/2013 18:14, David Rush wrote:
> Total noob to PostgreSQL and PostGIS here. Trying to follow examples
> from the Obe+Hsu book (1st Ed) in using shp2pgsql from the command
> line to import some tiger county data.
> I ran this:
> shp2pgsql -s 4269 -g geom_4269 -W LATIN1
> c:/users/david/downloads/tl_2012_us_county/tl_2012_us_county.shp
> public.us_counties psql -h localhost -U postgres -p 5432 -d mygisdb
> Thanks to an archive of this list that led me to add the "-W LATIN1"
> param (it was failing with an error w/out it).
> Now the command runs for several minutes, spitting out mostly zillions
> of hex digits, with no overt errors. Last line it spits out is "COMMIT;".
> But when I go into psql, I can't find the public.us_counties table
> that I thought I just added created:
> mygisdb=# select * from public.us_counties;
> ERROR: relation "public.us_counties" does not exist
> LINE 1: select * from public.us_counties;
> mygisdb=# select table_schema, table_name,table_type from
> information_schema.tables where
> table_schema not in ('pg_catalog','information_schema');
> table_schema | table_name | table_type
> public | geography_columns | VIEW
> public | geometry_columns | VIEW
> public | spatial_ref_sys | BASE TABLE
> ch01 | lu_franchises | BASE TABLE
> ch01 | fastfoods | BASE TABLE
> (5 rows)
> Poking around with pgAdmin III I can't find in anywhere, either.
> Is the new table us_counties hiding somewhere? Or did it quietly
> fail? Or what?
> David
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130412/1ef5e671/attachment.html>
