[postgis-users] Cut lat/lon to six decimal digits
Carsten Hogertz
carsten.hogertz at gmail.com
Tue Apr 16 07:05:20 PDT 2013
Thanks.
Indead I did. I also tried
trunc(ST_Y(geom), 6)
But it gives back:
Function round(double precision, integer) does not exist
2013/4/16 Hugues François <hugues.francois at irstea.fr>
> Hello,
> Did you simply try
> round(ST_Y(geom), 6) as lat
> round(ST_X(geom), 6) as lon
> Hugues.
> *From:* postgis-users-bounces at lists.osgeo.org [mailto:
> postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Carsten Hogertz
> *Sent:* Tuesday, April 16, 2013 3:51 PM
> *To:* PostGIS Users Discussion
> *Subject:* [postgis-users] Cut lat/lon to six decimal digits
> Hi everyone,
> I've got the following SQL to extract the lat/lon of a polygone:
> SELECT
> ROW_NUMBER () over () as id,
> name,
> geom,
> ST_Y(geom) as lat,
> ST_X(geom) as lon
> FROM (SELECT name, (ST_DumpPoints(geom)).* FROM timezones20032013) as foo
> It gives me back the lat and lon as a number with a lot of digits, e.g.:
> 42.4734992980957
> 1.71096694469452
> Instead what I need is:
> 42.473499
> 1.710967
> How could I change my SQL to get the result cut/rounded?
> Any help would be appreciated.
> Thanks in advance
> Carsten
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130416/b83a42df/attachment.html>
