[postgis-users] Cut lat/lon to six decimal digits
pcreso at pcreso.com
Tue Apr 16 10:41:21 PDT 2013
Carsten,
you could try:
SELECT ROW_NUMBER () over () as id, name,
geom, ST_Y(geom)::decimal(8,6) as lat, ST_X(geom)::decimal(9,6) as lonFROM (SELECT name, (ST_DumpPoints(geom)).* FROM timezones20032013) as foo
Brent Wood
On Tue, Apr 16, 2013 at 8:50 AM, Carsten Hogertz <carsten.hogertz at gmail.com> wrote:
Hi everyone,I've got the following SQL to extract the lat/lon of a polygone:
geom, ST_Y(geom) as lat, ST_X(geom) as lon FROM (SELECT name, (ST_DumpPoints(geom)).* FROM timezones20032013) as foo
It gives me back the lat and lon as a number with a lot of digits, e.g.:
42.47349929809571.71096694469452
Instead what I need is:42.4734991.710967
How could I change my SQL to get the result cut/rounded?
Any help would be appreciated.
Thanks in advanceCarsten
postgis-users mailing list
postgis-users at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
-----Inline Attachment Follows-----
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130416/c0c8fc79/attachment.html>
