[postgis-users] How/where does postgis hook a callback to free	cached geos structures?
    Stephen Woodbridge
    woodbri at swoodbridge.com
    Sun Apr 21 12:03:16 PDT 2013
Hi Mark,
I'm trying to rewrite the wrappers for the pagc address standardizer
such that I can create and cache the standardizer obj in a per query
cache. I think the following code modeled after GetGeomCache will do
what I need. The problem I'm having is that I need to somehow hook the
query shutdown code with a callback that will allow me to free the
standardizer.
void FreeStdCache(StdCache * cache)
   // free the cached objects
StdCache *GetStdCache(FunctionCallInfoData *fcinfo)
   MemoryContext old_context;
   StdCache *cache = fcinfo->flinfo->fn_extra;
   if (! cache) {
     old_context = MemoryContextSwitchTo(fcinfo->flinfo->fn_mcxt);
     cache = palloc(sizeof(StdCache));
     MemoryContextSwitchTo(old_context);
     cache->std = std_init();
     fcinfo->flinfo->fn_extra = cache;
     // ########## not sure how to do the following #############
     ExprContext *econtext = ?????;
     RegisterExprContextCallback(econtext, FreeStdCache, cache);
   return cache;
So my function is not an SRF. I would get called like:
select * from standardize_address(
   'lexicon', 'gazeteer', 'rules',
   '123 main st', 'boston ma 02001');
as a single request where we would construct the standardizer and then
free it. But in a query like the following, we would construct it, cache
it for each record, and free is when query shutdowns.
select (std).* from (
   select standardize_address('lexicon', 'gazeteer', 'rules', micro,
macro) as std from table_to_standardize) as foo;
I'm not sure if I can use RegisterExprContextCallback() to do this or of
there is a better way. And not sure how to get econtext? I think that
might only be available for SRF functions.
I saw Mark's inquiry here:
http://postgresql.1045698.n5.nabble.com/Any-advice-about-function-caching-td1936551.html
but could not find the code that registers the callback in postgis.
Here is a similar post:
http://web.archiveorange.com/archive/v/alpsnw9p7b8CWMh7hBPj
But neither have an example of how the issue was resolved. So a little
help or pointer would be appreciated.
Thanks,
   -Steve
