[postgis-users] How/where does postgis hook a callback to free cached geos structures?
Paul Ramsey pramsey at opengeo.org
Mon Apr 22 09:29:18 PDT 2013
The caching strategy used by proj and geos creates objects in memory
that live for the span of the STATEMENT, not the backend. So I
wouldn't worry too much about that. On the other hand, if you have a
lot of individual geocode requests coming in it could get expensive as
each one has to set up a cache object: just how expensive is that
process?
P.
On Sun, Apr 21, 2013 at 9:04 PM, Paragon Corporation <lr at pcorp.us> wrote:
> Sorry guys combining snippets from two separate emails here
>>  From memory, the PROJ.4 MemoryContext lives for the lifetime of a backend
> so you shouldn't see the destructor being called that often. If you want to
> use a similar trick for your standardizer, then take a look at the
> (disabled) GetPROJ4SRSCache code in the same file.
>> HTH,
>> Mark.
> Steve,
> I was thinking that it's not a bad idea for the LGR cache to live for the
> lifetime of the backend similar to what is done with Proj.
> Take the case of a web service where you'll be getting millions of one off
> requests for standardizing.  You'd want all these queries to share the same
> LGR if they request for the same LGR.
>> So the way this works is we create a STD object and load that with a
> lexicon, gazeteer and rules (LGR) tables. If we standardize a table with
> multiple country addresses
>> , then each country might have its own set of LGR tables so I would need
> to create hash with the LGR as the key to fetch the correct STD object. This
> seems to mirror the behavior of lwgeom_geos_prepared.c
>> Thanks,
>> - Steve
> I personally would start off with worrying about one set (and destroy and
> replace as needed).  Chances are most people will just be using one set so
> that will handle 90%.
> It will also make it a bit easier to debug I think.  Then when we have that
> working fairly well and stress tested, then add support for multiple LGR
> caches.
> Mark,
> Is it legal to kill a cache in a query call that did not create it (assuming
> they are running on same backend process).  Haven't looked at proj code and
> probably wouldn't understand it if I did, but assume that is what you are
> doing.
> Example like I described above:
> You have one query that uses us_LGR tables
> Then another query comes along (or even the same query), wanting gb_LGR
> And you are only maintaining one set of LGR in cache
> Is it possible for the second query -- to say "cache doesn't have what I
> need - wipe it out and replace with this new set?"
> Or can you only get away with that if both are in the same query call?
> I think performance wise we'd want multiple queries on same backend to share
> that.  I assume that there will be no contention since only one query can
> run at a time per backend.
> Thanks,
> Regina
> http://www.postgis.us
> http://postgis.net
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
