[postgis-users] Bug in postgis/lwgeom_geos_prepared.c
Stephen Woodbridge woodbri at swoodbridge.com
Mon Apr 22 10:04:59 PDT 2013
Hi Guys,
In reading through the code in "postgis/lwgeom_geos_prepared.c" I have
noticed a bug that you probably should fix:
static void
DeletePrepGeomHashEntry(MemoryContext mcxt)
     void **key;
     PrepGeomHashEntry *he;
     /* The hash key is the MemoryContext pointer */
     key = (void *)&mcxt;
     /* Delete the projection object from the hash */
     he = (PrepGeomHashEntry *) hash_search(PrepGeomHash, key,
HASH_REMOVE, NULL);
     he->prepared_geom = NULL;
     he->geom = NULL;
     if (!he)
         elog(ERROR, "DeletePrepGeomHashEntry: There was an error
removing the geometry object from this MemoryContext (%p)", (void *)mcxt);
Notice that  if he == NULL, you will never get to the if (!he) statement
because you will have already segv'd on the prior two statements trying
to access he.
-Steve
