[postgis-users] Incorrect Address Parsing
Shawn Peterson
shawnnpeterson at gmail.com
Tue Apr 23 23:45:35 PDT 2013
I was geocoding the following address:
SELECT g.rating, ST_X(g.geomout) As lon, ST_Y(g.geomout) As lat,
(addy).address As stno, (addy).streetname As street,
(addy).streettypeabbrev As styp, (addy).location As city,
(addy).stateabbrev As st,(addy).zip
FROM geocode('*100 El Camino Real, Menlo Park, CA 94025*') As g;
All the returned results are wrong, even cities don't match.
I did a workaround by manually supplying the address components:
FROM geocode(row*(100,'','El Camino Real','','','','Menlo Park', 'CA',
'94025',true)*::norm_addy) As g;
This second query gives a closer answer (street number is 101, on the other
side of the street). Is this the only workaround? This would assume my
addresses are already correctly parsed by another program.
It seems the problem is with address normalization:
SELECT normalize_address('100 El Camino Real, Menlo Park, CA 94025');
normalize_address
* (100,,Real,Cam,E,,"Menlo Park",CA,94025,t)*
(1 row)
On the other hand, geocoder.us can parse the address correctly, and it's on
the correct side of the street.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130423/13fe51a7/attachment.html>
