[postgis-users] Incorrect Address Normalization
Shawn Peterson shawnnpeterson at gmail.com
Thu Apr 25 14:07:50 PDT 2013
Hi Regina,
Thanks for the suggestions. I did search for similar posts but somehow I
missed that thread. I'll try the new code you are working on.
Thanks,
Shawn
On Thu, Apr 25, 2013 at 12:31 PM, Paragon Corporation <lr at pcorp.us> wrote:
> I have this problem ticketed already:
> http://trac.osgeo.org/postgis/ticket/1118
> In this particular case you'd be actually better off deleting those records
> and then it would normalize that particular variant right.
> The problem is that all those other Cams that tiger does put the Cam in the
> pre type field would then be wrong.
> As noted in the last item of ticket I'm working with Steve Woodbridge to
> have an alternative normalizer which should handle these issues better and
> we are in the heat of it at the moment so very much in flux.
> I haven't tried adding this entry to the new standardizer table set but
> will
> and see how it fairs. But it does behave the same right now for this
> particular case with the entries I currently have.
> If you are interested your can download the code from here and compile
> http://pagc.svn.sourceforge.net/viewvc/pagc/branches/sew-refactor/postgresql
> /?view=tar
> It creates a PostgreSQL extension you can install with
> CREATE EXTENSION address_standardizer;
> Lots of examples in this diatribe of this ticket:
> http://trac.osgeo.org/postgis/ticket/2260
> We are still working out some kinks as to how tiger is wrapping it and I
> need to add in a few more entries.
> In postgis 2.1
> CREATE EXTENSION postgis_tiger_geocoder;
> Then you can run
> SELECT pagc_normalize_address(youraddress);
> Instead of
> SELECT normalize_address(youraddress);
> And the tables used are tiger.pagc_lex, tiger.pagc_gaz, tiger.pagc_rules
> which you can add entries to.
> The other alternative more invasive solution which Steve suggested and he
> does for his geocoding work is to normalize the tiger dataset itself.
> I've been avoiding that solution (though it would work well with cases like
> this), just because its going to add more time to the data load process and
> also take up a bit more disk space.  Neither of which is all that appealing
> nor ones I've benchmarked.  It will also require a bit more work to add
> that
> logic to the prep step (though I think I probably overestimated the effort
> on that part).
> Thanks,
> Regina
> http://www.postgis.us
> http://postgis.net
> ________________________________
> From: postgis-users-bounces at lists.osgeo.org
> [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Shawn Peterson
> Sent: Thursday, April 25, 2013 12:22 PM
> To: PostGIS Users Discussion
> Subject: [postgis-users] Incorrect Address Normalization
> I was testing normalize_address on the following address:
> 100 El Camino Real, Menlo Park, CA 94025
> but it gives incorrect results. I tried to add the following entry to
> postgis-2.1.0SVN/extras/tiger_geocoder/tiger_2011/tables/lookup_tables_2011.
> sql:
>     FROM (VALUES
>         ('EL CAMINO', 'El Cam'),
>         ('CAM', 'Cam'),
>         ('CAM.', 'Cam'),
> and then run
> postgis-2.1.0SVN/extras/tiger_geocoder/tiger_2011/create_geocode.sh. But it
> does not work.
> My postgreSQL is 9.2.4, and postGIS is 2.1.0SVN.
> Any help is appreciated!
> Thanks,
> Shawn
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130425/58683227/attachment.html>
