[postgis-users] postgis restore using pg_dump and/or postgis_restore.pl
Birchall, Austen
austen.birchall at metoffice.gov.uk
Tue Apr 30 07:08:12 PDT 2013
If I do a pg_dump of a 8.4.13 postgis enable database for ERSI:
pg_dump -Fc testdb -U postgres > backup_file
How can I restore it using:
(i) Pg_restore - I've tried doing lots of things such as restoring public first but nothing seems to work. The issue seems to be that in the original database if I do a \dt as the dataowner user I created I get a listing that includes:
public | geometry_columns | table | postgres
public | sde_spatial_references | table | sde
public | spatial_ref_sys | table | postgres
sde | gdb_itemrelationships | table | sde
sde | gdb_itemrelationshiptypes | table | sde
sde | gdb_items | table | sde
sde | gdb_itemtypes | table | sde
sde | gdb_replicalog | table | sde
sde | gdb_tables_last_modified | table | sde
sde | i2 | table | sde
sde | i3 | table | sde
sde | i4 | table | sde
sde | i5 | table | sde
sde | i6 | table | sde
sde | sde_archives | table | sde
sde | sde_column_registry | table | sde
sde | sde_coordinate_systems | table | sde
sde | sde_dbtune | table | sde
sde | sde_geometry_columns | table | sde
sde | sde_layer_locks | table | sde
sde | sde_layer_stats | table | sde
sde | sde_layers | table | sde
sde | sde_lineages_modified | table | sde
sde | sde_locators | table | sde
sde | sde_logfile_pool | table | sde
sde | sde_metadata | table | sde
sde | sde_mvtables_modified | table | sde
sde | sde_object_ids | table | sde
sde | sde_object_locks | table | sde
sde | sde_process_information | table | sde
sde | sde_raster_columns | table | sde
sde | sde_server_config | table | sde
sde | sde_state_lineages | table | sde
sde | sde_state_locks | table | sde
sde | sde_states | table | sde
sde | sde_table_locks | table | sde
sde | sde_table_registry | table | sde
sde | sde_tables_modified | table | sde
sde | sde_version | table | sde
sde | sde_versions | table | sde
sde | sde_xml_columns | table | sde
sde | sde_xml_index_tags | table | sde
sde | sde_xml_indexes | table | sde
which I assume is a result of doing
grant usage on schema sde to public;
in psql as the sde user?
but on the restored database /dt only gives the public enties
I not at all sure how \dt works with permissions
(ii) Could I use postgis_restore.pl ? and if so how.
Many thanks
Austen Birchall
DBA
Met Office
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130430/8b6f95bc/attachment.html>
