[postgis-users] Problems installing on Linux
James David Smith
james.david.smith at gmail.com
Tue Aug 6 03:49:56 PDT 2013
On 6 August 2013 11:14, Mike Toews <mwtoews at gmail.com> wrote:
> On 6 August 2013 22:02, James David Smith <james.david.smith at gmail.com> wrote:
>> Thanks both. The first error is:
>> psql:/usr/pgsql-9.0/share/contrib/postgis-2.0/postgis.sql:49: ERROR:
>> could not load library "/usr/pgsql-9.0/lib/postgis-2.0.so":
>> /usr/pgsql-9.0/lib/postgis-2.0.so: undefined symbol:
>> GEOSRelatePatternMatch
>> Thanks
>> James
> You will need a newer GEOS library. Check your current version with:
> $ geos-config --version
> See the handy PostGIS Support Matrix to help you out:
> http://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS
> -Mike
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Hi Mike,
Thanks for the reply. I thought that I had the latest version of GEOS,
so I just did 'locate geos' and it found quite a few files. They seem
to be grouped into the below folders:
/depot/shared/geos-3.0.3/
/depot/shared/geos-3.3.5/
/opt/geos-3.3.8/include/geos/
/depot/shared/pgrouting/geos-3.0.0/
/depot/shared/pgrouting/geos-3.3.5/
/opt/Geos/
I guess that this is causing the problem.
Though when I do the "./configure" command for PostGIS I have been
pointing the it towards:
/opt/geos-3.3.8/bin/geos-config
Which should make it use the latest version of GEOS no?
Sorry for not being very technical, I'm slowly getting the hang of linux...
Thanks
James
