[postgis-users] Problems installing on Linux
James David Smith
james.david.smith at gmail.com
Tue Aug 6 09:53:56 PDT 2013
On 6 August 2013 15:38, Rémi Cura <remi.cura at gmail.com> wrote:
> Hello,
> I had trouble with geos.
> Strangely, I had to turn postgres down, then make clean in geos, then build
> and install, then clean postgis, then build and install, then restart
> postgres.
> I had error if not stopping my (local) server, and if not cleaning geos and
> postgis before building
> Cheers,
> Rémi-C
> 2013/8/6 Mike Toews <mwtoews at gmail.com>
>> On 6 August 2013 22:49, James David Smith <james.david.smith at gmail.com>
>> wrote:
>> > Hi Mike,
>> > Thanks for the reply. I thought that I had the latest version of GEOS,
>> > so I just did 'locate geos' and it found quite a few files. They seem
>> > to be grouped into the below folders:
>> > /depot/shared/geos-3.0.3/
>> > /depot/shared/geos-3.3.5/
>> > /opt/geos-3.3.8/include/geos/
>> > /depot/shared/pgrouting/geos-3.0.0/
>> > /depot/shared/pgrouting/geos-3.3.5/
>> > /opt/Geos/
>> > I guess that this is causing the problem.
>> > Though when I do the "./configure" command for PostGIS I have been
>> > pointing the it towards:
>> > /opt/geos-3.3.8/bin/geos-config
>> > Which should make it use the latest version of GEOS no?
>> > Sorry for not being very technical, I'm slowly getting the hang of
>> > linux...
>> > Thanks
>> > James
>> Technical is always good here. Sometimes it is necessary to update the
>> shared library cache by running "ldconfig" after various "make
>> install" commands. It might need to be run as root (or with sudo, if
>> you have that).
>> Also, sometimes, it could be also necessary to either add the LIBDIR
>> to /etc/ld.so.conf, or add a .conf file in /etc/ld.so.conf.d/, or to
>> fiddle around with the LD_LIBRARY_PATH environment variable to point
>> to the directory with the current versions of .so shared libraries.
>> After any changes with these, run "ldconfig" to update the system
>> cache. Yet another good tool is "ldd" to see which libraries are being
>> loaded. For example:
>> $ ldd /usr/pgsql-9.0/lib/postgis-2.0.so
>> should show you which other .so objects are being referenced.
>> -Mike
Hi Mike/Remy/all,
Thanks for your help. I'm making progress. Please see below. My
install is now using geos-3.3.8. Or seems to be.
linux-vdso.so.1 => (0x00007fff735fc000)
libgeos_c.so.1 => /opt/Geos/lib/libgeos_c.so.1 (0x00002b4411d4d000)
libproj.so.0 => /opt/Proj/lib/libproj.so.0 (0x00002b4411f74000)
libjson.so.0 => /opt/json/lib/libjson.so.0 (0x00002b44121ca000)
libxml2.so.2 => /opt/LibXml/lib/libxml2.so.2 (0x00002b44123cb000)
libz.so.1 => /usr/lib64/libz.so.1 (0x00002b441270e000)
libm.so.6 => /lib64/libm.so.6 (0x00002b4412922000)
libc.so.6 => /lib64/libc.so.6 (0x00002b4412ba5000)
libgeos-3.3.8.so => /opt/Geos/lib/libgeos-3.3.8.so
libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x00002b44132ab000)
libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00002b44135ab000)
libjson-c.so.2 => /opt/json/lib/libjson-c.so.2 (0x00002b44137ba000)
libdl.so.2 => /lib64/libdl.so.2 (0x00002b44139c3000)
/lib64/ld-linux-x86-64.so.2 (0x0000003f53000000)
The following commands now seem to work:
psql -d yourdatabase -f postgis.sql
psql -d yourdatabase -f postgis_comments.sql
psql -d yourdatabase -f spatial_ref_sys.sql
And when I go into my database and do SELECT postgis_full_version I
get the following:
POSTGIS="2.0.4SVN r11660" GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel. 4.6.1, 21
August 2008" LIBXML="2.7.6" LIBJSON="UNKNOWN" TOPOLOGY
However it says that Topology and Raster support are not present. So I
thought that I could now run the following commands to install those
too:
psql -d yourdatabase -f rtpostgis.sql
psql -d yourdatabase -f raster_comments.sql
psql -d yourdatabase -f topology/topology.sql
psql -d yourdatabase -f doc/topology_comments.sql
However when I run them I get an error. The first line is:
psql:/usr/pgsql-9.0/share/contrib/postgis-2.0/rtpostgis.sql:48: ERROR:
could not load library "/usr/pgsql-9.0/lib/rtpostgis-2.0.so":
libgeos-3.2.0.so: cannot open shared object file: No such file or
directory
Any idea why there is still mention of libgeos-3.2.0 ? I thought I'd
sorted that out now?
Thanks
James
