[postgis-users] Problems installing on Linux
Rémi Cura remi.cura at gmail.com
Tue Aug 6 07:38:17 PDT 2013
Hello,
I had trouble with geos.
Strangely, I had to turn postgres down, then make clean in geos, then build
and install, then clean postgis, then build and install, then restart
postgres.
I had error if not stopping my (local) server, and if not cleaning geos and
postgis before building
Cheers,
Rémi-C
2013/8/6 Mike Toews <mwtoews at gmail.com>
> On 6 August 2013 22:49, James David Smith <james.david.smith at gmail.com>
> wrote:
> > Hi Mike,
> > Thanks for the reply. I thought that I had the latest version of GEOS,
> > so I just did 'locate geos' and it found quite a few files. They seem
> > to be grouped into the below folders:
> > /depot/shared/geos-3.0.3/
> > /depot/shared/geos-3.3.5/
> > /opt/geos-3.3.8/include/geos/
> > /depot/shared/pgrouting/geos-3.0.0/
> > /depot/shared/pgrouting/geos-3.3.5/
> > /opt/Geos/
> > I guess that this is causing the problem.
> > Though when I do the "./configure" command for PostGIS I have been
> > pointing the it towards:
> > /opt/geos-3.3.8/bin/geos-config
> > Which should make it use the latest version of GEOS no?
> > Sorry for not being very technical, I'm slowly getting the hang of
> linux...
> > Thanks
> > James
> Technical is always good here. Sometimes it is necessary to update the
> shared library cache by running "ldconfig" after various "make
> install" commands. It might need to be run as root (or with sudo, if
> you have that).
> Also, sometimes, it could be also necessary to either add the LIBDIR
> to /etc/ld.so.conf, or add a .conf file in /etc/ld.so.conf.d/, or to
> fiddle around with the LD_LIBRARY_PATH environment variable to point
> to the directory with the current versions of .so shared libraries.
> After any changes with these, run "ldconfig" to update the system
> cache. Yet another good tool is "ldd" to see which libraries are being
> loaded. For example:
> $ ldd /usr/pgsql-9.0/lib/postgis-2.0.so
> should show you which other .so objects are being referenced.
> -Mike
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130806/42523553/attachment.html>
