[postgis-users] No SFCGAL static?
Oliver Courtin olivier.courtin at oslandia.com
Tue Aug 20 08:43:23 PDT 2013
Le 20 août 2013 à 17:08, William Kyngesburye a écrit :
Hi William,
> The readme doesn't say anything, but when I try to configure PostGIS with a static SFCGAL, it gives a *warning* that sfcgal is static, and the status at the end says sfcgal support disabled.
> Why can't I use a static SFCGAL?  I'd like a simpler installation with as few non-standard external links as possible, but if it's critical to have a shared library I can live with it.  And the readme should mention this requirement.
As we recall, it's was related to SFCGAL dependancies.
Could worth to give it a try, with all dependancies (Boost, CGAL) as static,
and SFCGAL static too.
(so need to bypass postgis configure check)
HTH,
O.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20130820/88667a55/attachment.html>
