[postgis-users] Why unrecognized field type?
Lee Hachadoorian Lee.Hachadoorian+L at gmail.com
Tue Dec 3 07:55:01 PST 2013
On Tue, Dec 3, 2013 at 5:23 AM, James David Smith <
james.david.smith at gmail.com> wrote:
> Hi all,
> Apologies for cross-posting this to the RPostrgeSQL and PostGIS mailing
> lists, but I'm not sure where the problem lies.
> I am using the RPostgreSQL package of R to connect to my installation of
> PostgreSQL/PostGIS. I want to retrieve some coordinates from my database
> and run the below command. Is this just that R doesn't know what to do with
> Geometry's, or is it something I should be more concerned about? I ask, as
> I'm having some wider issues with my workflow and this may be related.
> Thanks
> James
> > dbGetQuery(con, "SELECT st_transform(st_setsrid(st_makepoint(soose::numeric, soosn::numeric),27700),4326) FROM stage WHERE ssid = '707187161010202'")
> st_transform
> 1 0101000020E6100000F71184EF3961B3BF830420AF33C64940Warning message:In postgresqlExecStatement(conn, statement, ...) :
>   RS-DBI driver warning: (unrecognized PostgreSQL field type geometry (id:480912) in column 0)
James,
R knows how to handle geometries using the sp package, but can't read the
data in using RPostgreSQL. You would need to use readOGR() in the rgdal
package. But what data do you actually need in R, and what do you intend to
do with it? If you're not going to be mapping it or doing spatial
statistics on it, there may be a way to get the data you want using
RPostgreSQL.
Best,
--Lee
Lee Hachadoorian
Asst Professor of Geography, Dartmouth College
http://freecity.commons.gc.cuny.edu/
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131203/24dc7ec2/attachment.html>
