[postgis-users] biggest rectangle contained within another polygon
tommaso
tommasodb at googlemail.com
Fri Dec 6 02:36:43 PST 2013
Thanks for you help, I will give a try.
Tommaso
On 12/05/2013 10:14 AM, Rémi Cura wrote:
> Maybe you could try with a more powerfull langage,
> like PL-R.
> You would probably find some already existing useful brick for what
> you want to do.
> Cheers,
> Rémi-C
> 2013/12/5 Martin Davis <mtnclimb at telus.net <mailto:mtnclimb at telus.net>>
> Is there an existing function to do this? No.
> Is it easy to write such a function? No, not if
> http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.47.3370&rep=rep1&
> type=pdf
> is the simplest algorithm for solving this problem in general terms.
> An interesting problem, though. Would be useful for labelling
> purposes.
> On 12/4/2013 2:06 AM, tommaso wrote:
> Hello, I need to calculate the biggest rectangle which is
> contained within another polygon. A sort of inner envelope or
> inner bounding box.
> I found this interesting article:
> http://cgm.cs.mcgill.ca/~athens/cs507/Projects/2003/DanielSud/
> <http://cgm.cs.mcgill.ca/%7Eathens/cs507/Projects/2003/DanielSud/>
> Is it possible in Postgis?
> I have attached a picture with a example of what I need.
> postgis-users mailing list
> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131206/852d4495/attachment.html>
