[postgis-users] functions
tommaso
tommasodb at googlemail.com
Mon Dec 9 09:57:13 PST 2013
This should work:
create or replace function flow(integer) RETURNS TABLE (gid int, geom
geometry, geojson text) AS
WITH RECURSIVE flow(gid, geom) AS (
SELECT e.gid, e.geom FROM electric_line e, fuses f WHERE
ST_DWithin(ST_AsText(e.geom)::geometry, ST_AsText(f.geom)::geometry,
0.01) AND f.gid=$1
UNION ALL
SELECT n.gid, n.geom
FROM electric_line n, flow f
WHERE ST_DWithin(ST_EndPoint(f.geom),ST_StartPoint(n.geom),0.01)
SELECT *, ST_ASGeoJSON(ST_Transform(geom,4326),6) AS geojson
FROM flow;
LANGUAGE SQL;
SELECT * FROM flow(1);
On 12/09/2013 03:57 PM, Jonatan Malaver wrote:
> Hello,
> I'm new to postgis/postgresql. I was wondering if anyone could tell
> me how to make a function out of this sql query:
> 0.01) AND f.gid=' . $_GET['fuse'] . '
> UNION ALL
> FROM flow;
> I'd like to make a function flow(gid)
> Thanks,
> Jon
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131209/0a55803b/attachment.html>
