[postgis-users] functions
Jonatan Malaver
jon.malaver at shrewsburyma.gov
Mon Dec 9 17:51:39 PST 2013
Thank you!!!
Jon
From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of tommaso
Sent: Monday, December 09, 2013 12:57 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] functions
This should work:
create or replace function flow(integer) RETURNS TABLE (gid int, geom geometry, geojson text) AS
WITH RECURSIVE flow(gid, geom) AS (
SELECT e.gid, e.geom FROM electric_line e, fuses f WHERE ST_DWithin(ST_AsText(e.geom)::geometry, ST_AsText(f.geom)::geometry, 0.01) AND f.gid=$1
UNION ALL
SELECT n.gid, n.geom
FROM electric_line n, flow f
WHERE ST_DWithin(ST_EndPoint(f.geom),ST_StartPoint(n.geom),0.01)
SELECT *, ST_ASGeoJSON(ST_Transform(geom,4326),6) AS geojson
FROM flow;
LANGUAGE SQL;
SELECT * FROM flow(1);
On 12/09/2013 03:57 PM, Jonatan Malaver wrote:
Hello,
I'm new to postgis/postgresql. I was wondering if anyone could tell me how to make a function out of this sql query:
SELECT e.gid, e.geom FROM electric_line e, fuses f WHERE ST_DWithin(ST_AsText(e.geom)::geometry, ST_AsText(f.geom)::geometry, 0.01) AND f.gid=' . $_GET['fuse'] . '
UNION ALL
FROM flow;
I'd like to make a function flow(gid)
Thanks,
Jon
postgis-users mailing list
postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131210/463627a3/attachment.html>
