[postgis-users] functions
Rémi Cura
remi.cura at gmail.com
Tue Dec 10 02:20:34 PST 2013
On a more high level:
I'm guessing you are using the recursive cte to walk trough a graph.
There are ways to accelerate this, but at the cost of increase of memory
usage and duplication of data.
It depends a lot on you graph properties (has it a lots of nodes,
connectivity, centralness, etc)
(of course you have an index on "gid" or it is a primary key (implicit
index) ).
If perf is really an issue, you could turn to more specialize grpah db
(look for spar-ql)
Cheers,
Rémi-C
2013/12/10 tommaso <tommasodb at googlemail.com>
> Why do you do ST_AsText(e.geom)::geometry? This is equivalent to e.geom.
> Change the query so:
> SELECT e.gid, e.geom FROM electric_line e, fuses f WHERE
> ST_DWithin(e.geom, f.geom 0.01) AND f.gid=$1 .....
> No sure if it does help, but you you can also try so:
> SELECT e.gid, e.geom FROM electric_line e JOIN fuses f ON
> ST_DWithin(e.geom, f.geom, 0.01) WHERE f.gid=$1
> Also
> WHERE ST_DWithin(ST_EndPoint(f.geom),ST_StartPoint(n.geom),0.01)
> can be changed to:
> WHERE ST_Distance(ST_EndPoint(f.geom),ST_StartPoint(n.geom)) <= 0.01
> which should be faster.
> Obviously you need a GIST index on booth geometry columns.
> If it all does not help please attach some test data.
> Cheers, Tommaso
> On 12/10/2013 03:01 AM, Jonatan Malaver wrote:
> Another question, what can I do to improve performance on the query? The
> query can take 2 seconds or more.
> *From:* postgis-users-bounces at lists.osgeo.org [
> mailto:postgis-users-bounces at lists.osgeo.org<postgis-users-bounces at lists.osgeo.org>]
> *On Behalf Of *Jonatan Malaver
> *Sent:* Monday, December 09, 2013 8:52 PM
> *To:* PostGIS Users Discussion
> *Subject:* Re: [postgis-users] functions
> Thank you!!!
> Jon
> *On Behalf Of *tommaso
> *Sent:* Monday, December 09, 2013 12:57 PM
> This should work:
> create or replace function flow(integer) RETURNS TABLE (gid int, geom
> geometry, geojson text) AS
> WITH RECURSIVE flow(gid, geom) AS (
> ST_DWithin(ST_AsText(e.geom)::geometry, ST_AsText(f.geom)::geometry, 0.01)
> AND f.gid=$1
> UNION ALL
> SELECT n.gid, n.geom
> FROM electric_line n, flow f
> SELECT *, ST_ASGeoJSON(ST_Transform(geom,4326),6) AS geojson
> FROM flow;
> LANGUAGE SQL;
> SELECT * FROM flow(1);
> On 12/09/2013 03:57 PM, Jonatan Malaver wrote:
> Hello,
> I’m new to postgis/postgresql. I was wondering if anyone could tell me
> how to make a function out of this sql query:
> AND f.gid=' . $_GET['fuse'] . '
> UNION ALL
> FROM flow;
> I’d like to make a function flow(gid)
> Thanks,
> Jon
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> postgis-users mailing listpostgis-users at lists.osgeo.orghttp://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131210/c4d38127/attachment.html>
