[postgis-users] Postgis 2.1.0 poor performance vs Postgis 2.0.3
Moen, Paul T.
pmoen at nd.gov
Tue Dec 10 09:00:57 PST 2013
Steve,
That did the trick in a big way. I will make ANALYZE a step in my upgrade
process from now on.
My new query after the ANALYZE.
--select
"flow_type","feat_type",encode(ST_AsBinary(ST_Force2D("the_geom"),'NDR'),'h
ex') as geom,"gid" from basemap.water24k_line where the_geom &&
ST_GeomFromText('POLYGON((1564746.75408708
903581.471987315,1564746.75408708 938518.971987315,1599744.49115605
938518.971987315,1599744.49115605 903581.471987315,1564746.75408708
903581.471987315))',2266);
Total query runtime: 569 ms.
344 rows retrieved.
Thank you very much,
Paul
On 12/10/13, 10:02 AM, "Stephen Woodbridge" <woodbri at swoodbridge.com>
wrote:
>Paul,
>Did you ANALYZE the new database after you upgraded it to 2.1.0?
>Try that and rerun your query and see if that helps.
>-Steve
>On 12/10/2013 10:46 AM, Moen, Paul T. wrote:
>> I have a table of multilines that the query below slows down
>> considerably after upgrading to postgis 2.1.0.
>> I am running the following Postgis.
>> "POSTGIS="2.0.3 r11128" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0,
>> 6 March 2012" GDAL="GDAL 1.10.1, released 2013/08/26" LIBXML="2.7.3"
>> LIBJSON="UNKNOWN" TOPOLOGY RASTER"
>> Below is a query that is created by Mapserver 6.0.3 that I am running in
>> pgAdmin.
>> -- Executing query:
>> select
>>"flow_type","feat_type",encode(ST_AsBinary(ST_Force_2D("the_geom"),'NDR')
>>,'hex')
>> 344 rows retrieved.
>> After upgrading to Postgis 2.1.0,
>> "POSTGIS="2.1.0 r11822" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0,
>> the same query takes over 10 times the time.
>> -- Executing query:
>> select
>>,'hex')
>> --select postgis_full_version();
>> --alter extension postgis_topology update to '2.1.0';
>> WARNING: ST_Force_2d signature was deprecated in 2.1.0. Please use
>> ST_Force2D
>> CONTEXT: SQL function "st_force_2d" during startup
>> Total query runtime: 6202 ms.
>> 344 rows retrieved.
>> Changing ST_Force_2D to ST_Force2D helped quite a bit, but it is still
>> twice as slow as Postgis 2.0.3.
>> -- Executing query:
>> select
>>'hex')
>> Total query runtime: 1029 ms.
>> 344 rows retrieved.
>> Is performance hit expected?
>> Thanks for any insight,
>> Paul
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
