[postgis-users] Postgis 2.1.0 poor performance vs Postgis 2.0.3
Stephen Woodbridge woodbri at swoodbridge.com
Tue Dec 10 09:09:13 PST 2013
Paul,
Cool! And yes, anytime you load a database or table like from shp2pgsql
you should analyze it to update the database statistics other wise the
planner has no information about what indexes to use. This might be a
good practice after adding a new index or making lots of changes to an
existing index doing updates/deletes/inserts on a table.
-Steve
On 12/10/2013 12:00 PM, Moen, Paul T. wrote:
> Steve,
> That did the trick in a big way.  I will make ANALYZE a step in my upgrade
> process from now on.
> My new query after the ANALYZE.
> --select
> "flow_type","feat_type",encode(ST_AsBinary(ST_Force2D("the_geom"),'NDR'),'h
> ex') as geom,"gid" from basemap.water24k_line where the_geom &&
> ST_GeomFromText('POLYGON((1564746.75408708
> 903581.471987315,1564746.75408708 938518.971987315,1599744.49115605
> 938518.971987315,1599744.49115605 903581.471987315,1564746.75408708
> 903581.471987315))',2266);
> Total query runtime: 569 ms.
> 344 rows retrieved.
> Thank you very much,
> Paul
> On 12/10/13, 10:02 AM, "Stephen Woodbridge" <woodbri at swoodbridge.com>
> wrote:
>> Paul,
>> Did you ANALYZE the new database after you upgraded it to 2.1.0?
>> Try that and rerun your query and see if that helps.
>> -Steve
>> On 12/10/2013 10:46 AM, Moen, Paul T. wrote:
>>> I have a table of multilines that the query below slows down
>>> considerably after upgrading to postgis 2.1.0.
>>> I am running the following Postgis.
>>> "POSTGIS="2.0.3 r11128" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0,
>>> 6 March 2012" GDAL="GDAL 1.10.1, released 2013/08/26" LIBXML="2.7.3"
>>> LIBJSON="UNKNOWN" TOPOLOGY RASTER"
>>> Below is a query that is created by Mapserver 6.0.3 that I am running in
>>> pgAdmin.
>>> -- Executing query:
>>> select
>>> "flow_type","feat_type",encode(ST_AsBinary(ST_Force_2D("the_geom"),'NDR')
>>> ,'hex')
>>> 344 rows retrieved.
>>> After upgrading to Postgis 2.1.0,
>>> "POSTGIS="2.1.0 r11822" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0,
>>> the same query takes over 10 times the time.
>>> -- Executing query:
>>> select
>>> ,'hex')
>>> --select postgis_full_version();
>>> --alter extension postgis_topology update to '2.1.0';
>>> WARNING:  ST_Force_2d signature was deprecated in 2.1.0. Please use
>>> ST_Force2D
>>> CONTEXT:  SQL function "st_force_2d" during startup
>>> Total query runtime: 6202 ms.
>>> 344 rows retrieved.
>>> Changing ST_Force_2D to ST_Force2D helped quite a bit, but it is still
>>> twice as slow as Postgis 2.0.3.
>>> -- Executing query:
>>> select
>>> 'hex')
>>> Total query runtime: 1029 ms.
>>> 344 rows retrieved.
>>> Is performance hit expected?
>>> Thanks for any insight,
>>> Paul
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
