[postgis-users] Postgis 2.1.0 poor performance vs Postgis 2.0.3
Paul Ramsey pramsey at cleverelephant.ca
Tue Dec 10 10:01:36 PST 2013
Might also be a nice thing for us to add to the end of the load process :/
On Tue, Dec 10, 2013 at 12:09 PM, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
> Paul,
> Cool! And yes, anytime you load a database or table like from shp2pgsql you
> should analyze it to update the database statistics other wise the planner
> has no information about what indexes to use. This might be a good practice
> after adding a new index or making lots of changes to an existing index
> doing updates/deletes/inserts on a table.
> -Steve
> On 12/10/2013 12:00 PM, Moen, Paul T. wrote:
>> Steve,
>> That did the trick in a big way.  I will make ANALYZE a step in my upgrade
>> process from now on.
>> My new query after the ANALYZE.
>> --select
>> "flow_type","feat_type",encode(ST_AsBinary(ST_Force2D("the_geom"),'NDR'),'h
>> ex') as geom,"gid" from basemap.water24k_line where the_geom &&
>> ST_GeomFromText('POLYGON((1564746.75408708
>> 903581.471987315,1564746.75408708 938518.971987315,1599744.49115605
>> 938518.971987315,1599744.49115605 903581.471987315,1564746.75408708
>> 903581.471987315))',2266);
>> Total query runtime: 569 ms.
>> 344 rows retrieved.
>> Thank you very much,
>> Paul
>> On 12/10/13, 10:02 AM, "Stephen Woodbridge" <woodbri at swoodbridge.com>
>> wrote:
>>> Paul,
>>> Did you ANALYZE the new database after you upgraded it to 2.1.0?
>>> Try that and rerun your query and see if that helps.
>>> -Steve
>>> On 12/10/2013 10:46 AM, Moen, Paul T. wrote:
>>>> I have a table of multilines that the query below slows down
>>>> considerably after upgrading to postgis 2.1.0.
>>>> I am running the following Postgis.
>>>> "POSTGIS="2.0.3 r11128" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0,
>>>> 6 March 2012" GDAL="GDAL 1.10.1, released 2013/08/26" LIBXML="2.7.3"
>>>> LIBJSON="UNKNOWN" TOPOLOGY RASTER"
>>>> Below is a query that is created by Mapserver 6.0.3 that I am running in
>>>> pgAdmin.
>>>> -- Executing query:
>>>> select
>>>> "flow_type","feat_type",encode(ST_AsBinary(ST_Force_2D("the_geom"),'NDR')
>>>> ,'hex')
>>>> 344 rows retrieved.
>>>> After upgrading to Postgis 2.1.0,
>>>> "POSTGIS="2.1.0 r11822" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0,
>>>> the same query takes over 10 times the time.
>>>> -- Executing query:
>>>> select
>>>> ,'hex')
>>>> --select postgis_full_version();
>>>> --alter extension postgis_topology update to '2.1.0';
>>>> WARNING:  ST_Force_2d signature was deprecated in 2.1.0. Please use
>>>> ST_Force2D
>>>> CONTEXT:  SQL function "st_force_2d" during startup
>>>> Total query runtime: 6202 ms.
>>>> 344 rows retrieved.
>>>> Changing ST_Force_2D to ST_Force2D helped quite a bit, but it is still
>>>> twice as slow as Postgis 2.0.3.
>>>> -- Executing query:
>>>> select
>>>> 'hex')
>>>> Total query runtime: 1029 ms.
>>>> 344 rows retrieved.
>>>> Is performance hit expected?
>>>> Thanks for any insight,
>>>> Paul
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at lists.osgeo.org
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
