[postgis-users] Moving to AWS RDS PostgreSQL
Paul & Caroline Lewis
paulcaz80 at hotmail.com
Wed Dec 11 01:12:33 PST 2013
Thanks for the feedback,
PostGIS is installed as well as topology based on following AWS docs:
http://docs.aws.amazon.com/AmazonRDS/latest/UserGuide/Appendix.PostgreSQL.CommonDBATasks.html#Appendix.PostgreSQL.CommonDBATasks.PostGIS
AFAIK you cannot terminal/SSH into the RDS platform to go routing around for directories and files, you can only log in through psql or the likes of PGADMIN, phppgadmin.
Anyway, the first problem is probably that I've being using the previously emailed commands on the original server, which is installed with pg9.1/postgis1.5, so calling perl utils/postgis_restore.pl /some_location/db.backup is requesting an old script relevant to postgis 1.5 I presume.
What I'll try is setting up a new server with pg9.3/postgis2.1 and converting the 1.5 DB dump of the original email to 2.1 through the typical methods.Then I can just use the following docs to port the new temporary server DB dump into RDS.http://docs.aws.amazon.com/AmazonRDS/latest/UserGuide/PostgreSQL.Procedural.Importing.html I'll update if this works.Thanks,Paul>Did you install PostGIS and topology extensions in your new DB BEFORE
doing your command?
>CREATE EXTENSION postgis;
>CREATE EXTENSION topology;
>Run also legacy.sql in your new DB to ensure compliance with the old
PostGIS functions if you use PostGIS with an old application. The script
should be near the directory where you can find 'psql' command (ex.:
/usr/bin/psql ==> /usr/bin/share/contrib/postgis-2.0) in Ubuntu when you
install EnterpriseDB package.
>Regards
>Sylvain Racine
>iGreffe Géomatique
>50, St-Hubert, n° 5
>Granby, Québec
>J2G 5L9
>Tél: 450-770-9974
>Le 2013-12-10 16:27, Paul & Caroline Lewis a écrit :
>> I can connect fine using psql and a select version(); responds with
>> POSTGRESQL 9.3.1 ON X86_64-UNKNOWN-LINUX-GNU, COMPILED BY GCC (GCC) 4.6.3 20120306 (RED HAT 4.6.3-2), 64-BIT
>> I have also created the PostGIS extension on the DB I've created in the RDS version through PGADMIN.
>> Tried exporting PGPASSWORD but still no joy. Having it exported stops the password prompt and the psql connection is still fine.
>> The errors.txt file is empty based on the commands line in previous mail.
>> If I remove the target DB from the command line the errors.txt has a FATAL db does not exist error.
>> If I remove the target DB from postgresql through PGADMIN and run the command line, errors.txt contains the FATAL db does not exist error.
>> If I change the user the errors.txt file populates with a user error.
>> So the RDS platform is getting connected to but it would seem that the pipe dies because when the PGPASSWORD is set and users are correct and DB's in place the process starts but dies immediately with no error messages.
>> Will continue to search for what next.
>> Thanks again,
>> Paul
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users [1]
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131211/a2d29784/attachment.html>
