[postgis-users] Old question resurfacing
Gerry Creager - NOAA Affiliate gerry.creager at noaa.gov
Wed Dec 11 09:19:08 PST 2013
The radar data are freely available and while I'm working with an older
lidar ceilometer, I can make those data available to you, too. If you need
real time WSR88D data, I'll have to work with you on that, and we'll get a
data feed from another organization.
Specifically, what I'm working on is to push the radar data into a database
(pointcloud really does look promising) and retrieve it as point
observations for what we call data assimilation to help improve weather
models. I'm working on placing other data into a PostGIS database for
surface observations, etc.
Note that the ceilometer data is a VERY straightforward array every 'n'
seconds and won't pose a problem in stuffing it into a database. The
intriguing thing about a spatial database for lidar ceilometer data is the
ease in plotting individual sites' data. OR, if you were to place a grid of
these things out on a test site, to look at tomographs of the lower
atmosphere ("Boundary Layer").
gerry
On Wed, Dec 11, 2013 at 8:49 AM, Basques, Bob (CI-StPaul) <
bob.basques at ci.stpaul.mn.us> wrote:
>  Hmm,
> I’m working with the Minneapolis International Airport (MSP) on a project,
> any chance that  data is open/accessible enough to play with?  This could
> tie directly into a project I’m already working on.
> Thanks
> Bobb
> *From:* postgis-users-bounces at lists.osgeo.org [mailto:
> postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Gerry Creager -
> NOAA Affiliate
> *Sent:* Tuesday, December 10, 2013 2:14 PM
> *To:* PostGIS Users Discussion
> *Subject:* Re: [postgis-users] Old question resurfacing
> Bob, all:
> I agree. I'll have to spend some time with pointcloud but it DOES look
> very promising.
> Another application? Lidar. Pointed at the sky, not at the ground (we use
> 'em to determine cloud layers [ceiling] and sky cover at airports for
> aviation data...).
> Thanks, all!
> gerry
> On Tue, Dec 10, 2013 at 1:49 PM, Basques, Bob (CI-StPaul) <
> Gerry,
> Remi’s idea about using a point cloud may be spot on for your use.  It
> allows you to set a point cloud down to a revolution if need be, which
> seems like what you are looking for..  If the data becomes too massive for
> insertion into DB at real-time speeds, then you could also separate this
> revolution into separate DB’s as well, you could separate a whole number of
> ways, by elevation, or quadrant, or . . .
> I’m very interested in visualization possibilities with something like
> this being available in a database.  We’re doing some similar db 3d
> visualization stuff on some rather dense point clouds.  Your data once
> available could use the same visualizer.
> Bobb
> NOAA Affiliate
> *Sent:* Tuesday, December 10, 2013 1:41 PM
> Bob
> At least preliminarily, I can post-process, so speed of db adds isn't too
> troubling. Maintaining accurate representation of the bin-volume data is,
> however, important.
> Typical rotation is 1-3 RPM, and a complete volume scan takes ~11 min in
> clear air (where you best see biologicals if so inclined) or ~5 min in one
> of the storm data collection modes. These are for common WSR88D, stationary
> radars. SMARTR's and others we have here that are mobile present a whole
> host of other options/data eval and speed problems.
> Current radar data are nominally considered to have a horizontal
> resolution of ~250 m, ignoring distortion or keyholing due to
> range.Typically 16 elevations are scanned, once or or twice in storm mode
> and a few less elevations in clear air mode.
> Now, the interesting thing that's on the horizon is Phased Array Radar.
> When that happens, more data, more resolution, and faster updates.
> gerry
> On Tue, Dec 10, 2013 at 11:05 AM, Basques, Bob (CI-StPaul) <
> Gerry,
> Seems like the biggest hangup would be in adding the data to the DB fast
> enough.  How many points, per revolution, and what is the frequency of a
> revolution (stationary Radar, correct, although as I think about it, it
> could be mobile if needed, just need to add in the radar location to each
> record)?
> Bobb
> NOAA Affiliate
> *Sent:* Tuesday, December 10, 2013 10:52 AM
> *Subject:* [postgis-users] Old question resurfacing
> I asked this years ago, and I think Paul was less than pleased with me
> (:-), but:
> Has anyone, in the ensuing years looked at encoding radar data into a
> postGIS database? We've a little idea that might benefit one project, and
> getting the radar data into a good geospatial format would be
> beneficial.The data, of coure, would start out as radial-distance and
> intensity from the radar site, although we could preprocess it by gridding.
> Thanks, Gerry
> Gerry Creager
> NSSL/CIMMS
> 405.325.6371
> “Big whorls have little whorls,
> That feed on their velocity;
> And little whorls have lesser whorls,
> And so on to viscosity.”
> Lewis Fry Richardson (1881-1953)
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> Gerry Creager
> NSSL/CIMMS
> 405.325.6371
> Gerry Creager
> NSSL/CIMMS
> 405.325.6371
Gerry Creager
NSSL/CIMMS
405.325.6371
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20131211/4dd9b6bb/attachment.html>
