[postgis-users] Old question resurfacing
Frank Henze
henze at tu-cottbus.de
Thu Dec 12 11:16:53 PST 2013
Hi all,
briefly a few details to http://www2.htw-dresden.de/~s68071/3DWebGIS/:
- Projektauswahl: Baalbek and Palatin are static X3D models (no PostGIS)
- Projektauswahl: W3DS is dynamically generated from a PostGIS 2.0 DB
via a "GetScene"-request by Geoserver
I think Baalbek is too large (too many triangles) and therefore possibly
leads to crash. Palatin and W3DS should work.
The 3D window is a standard WebGL window based on X3DOM. So it should
run right stable.
Once again my question:
Is there an interest in a PostGIS 3D group?
Frank
Am 12.12.2013 16:55, schrieb Basques, Bob (CI-StPaul):
> Frank,
> Very nice. It froze up for me pretty quickly, I tried both FF and Chrome. Still looked good while it ran.
> This stability aspect is a big piece of being able to make something that folks will want to use. Data segregation will be a big piece moving forward I think.
> Bobb
> -----Original Message-----
> From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Frank Henze
> Sent: Thursday, December 12, 2013 6:04 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Old question resurfacing
> Hi Bobb,
> hi all,
> https://hub.sharedgeo.org/apps/x3d/ looks great!
> We have similar requirements for a 3d WebGIS.
> A first prototype you can find at:
> For "Projektauswahl:" select "W3DS"
> and then select "Historische Gebäude" (Historical Buildings)
> If there is nothing to see, then press on the left side "Alles anzeigen"
> We use the community buildt Geoserver incl. Web 3D service + X3DOM + JS.
> Some of our problems:
> How to import 3D geometries into PostGIS?
> Which formats and interfaces (CAD, X3D)?
> Point clouds in PostGIS (also import of).
> Is there a 3D PostGIS interest-group?
> If not, should one established?
> Frank
> Am 11.12.2013 17:44, schrieb Basques, Bob (CI-StPaul):
>> All,
>> Nothing that far along. Did a couple of proofs of concept so far,
>> I've done a couple of presentations on the Visualizer approach. We
>> tried a couple of different things, x3Dom, allover'js
>> You can see some of them here ( some of the pages take a while to
>> load the data in the background, be patient):
>> https://hub.sharedgeo.org/apps/x3d/ (these will generally need a
>> webGL enabled browser)
>> These are purely intended as a test of just how much data could easily
>> be squished into the browser before if blows, so you might experience
>> some failures. Ideally the data coming into these would be segmented
>> via a SQL call to PostGIS Pointcloud sources.
>> The last two in the list are using some point clouds cut from our
>> recent data collect at 8pt per sq meter for the City (6 billion points
>> in all), these are using about 300k points each for example.
>> Bobb
>> *From:*postgis-users-bounces at lists.osgeo.org
>> [mailto:postgis-users-bounces at lists.osgeo.org] *On Behalf Of *Rémi
>> Cura
>> *Sent:* Wednesday, December 11, 2013 10:08 AM
>> *To:* PostGIS Users Discussion
>> *Subject:* Re: [postgis-users] Old question resurfacing
>> I would be very interested to know any attempt to visualize 3D point
>> cloud from data base !
>> We did the same but our solution is far from perfect.
>> Bob, is you rporject public/open source, have you any paper/doc about it ?
>> Cheers,
>> Rémi-C
>> 2013/12/11 Basques, Bob (CI-StPaul) <bob.basques at ci.stpaul.mn.us
>> <mailto:bob.basques at ci.stpaul.mn.us>>
>> Hmm,
>> I'm working with the Minneapolis International Airport (MSP) on a
>> project, any chance that data is open/accessible enough to play with?
>> This could tie directly into a project I'm already working on.
>> Thanks
>> Bobb
>> <mailto:postgis-users-bounces at lists.osgeo.org>
>> <mailto:postgis-users-bounces at lists.osgeo.org>] *On Behalf Of *Gerry
>> Creager - NOAA Affiliate
>> *Sent:* Tuesday, December 10, 2013 2:14 PM
>> Bob, all:
>> I agree. I'll have to spend some time with pointcloud but it DOES look
>> very promising.
>> Another application? Lidar. Pointed at the sky, not at the ground (we
>> use 'em to determine cloud layers [ceiling] and sky cover at airports
>> for aviation data...).
>> Thanks, all!
>> gerry
>> On Tue, Dec 10, 2013 at 1:49 PM, Basques, Bob (CI-StPaul)
>> <bob.basques at ci.stpaul.mn.us <mailto:bob.basques at ci.stpaul.mn.us>> wrote:
>> Gerry,
>> Remi's idea about using a point cloud may be spot on for your use. It
>> allows you to set a point cloud down to a revolution if need be, which
>> seems like what you are looking for.. If the data becomes too massive
>> for insertion into DB at real-time speeds, then you could also
>> separate this revolution into separate DB's as well, you could
>> separate a whole number of ways, by elevation, or quadrant, or . . .
>> I'm very interested in visualization possibilities with something like
>> this being available in a database. We're doing some similar db 3d
>> visualization stuff on some rather dense point clouds. Your data once
>> available could use the same visualizer.
>> Bobb
>> *Sent:* Tuesday, December 10, 2013 1:41 PM
>> Bob
>> At least preliminarily, I can post-process, so speed of db adds isn't
>> too troubling. Maintaining accurate representation of the bin-volume
>> data is, however, important.
>> Typical rotation is 1-3 RPM, and a complete volume scan takes ~11 min
>> in clear air (where you best see biologicals if so inclined) or ~5 min
>> in one of the storm data collection modes. These are for common
>> WSR88D, stationary radars. SMARTR's and others we have here that are
>> mobile present a whole host of other options/data eval and speed problems.
>> Current radar data are nominally considered to have a horizontal
>> resolution of ~250 m, ignoring distortion or keyholing due to
>> range.Typically 16 elevations are scanned, once or or twice in storm
>> mode and a few less elevations in clear air mode.
>> Now, the interesting thing that's on the horizon is Phased Array Radar.
>> When that happens, more data, more resolution, and faster updates.
>> gerry
>> On Tue, Dec 10, 2013 at 11:05 AM, Basques, Bob (CI-StPaul)
>> Gerry,
>> Seems like the biggest hangup would be in adding the data to the DB
>> fast enough. How many points, per revolution, and what is the
>> frequency of a revolution (stationary Radar, correct, although as I
>> think about it, it could be mobile if needed, just need to add in the
>> radar location to each record)?
>> Bobb
>> *Sent:* Tuesday, December 10, 2013 10:52 AM
>> *Subject:* [postgis-users] Old question resurfacing
>> I asked this years ago, and I think Paul was less than pleased with me
>> (:-), but:
>> Has anyone, in the ensuing years looked at encoding radar data into a
>> postGIS database? We've a little idea that might benefit one project,
>> and getting the radar data into a good geospatial format would be
>> beneficial.The data, of coure, would start out as radial-distance and
>> intensity from the radar site, although we could preprocess it by gridding.
>> Thanks, Gerry
>> Gerry Creager
>> NSSL/CIMMS
>> 405.325.6371 <tel:405.325.6371>
>> "Big whorls have little whorls,
>> That feed on their velocity;
>> And little whorls have lesser whorls,
>> And so on to viscosity."
>> Lewis Fry Richardson (1881-1953)
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>> Gerry Creager
>> NSSL/CIMMS
>> Gerry Creager
>> NSSL/CIMMS
>> 405.325.6371
